MCAT Physics Problem: Elastic Properties of Solids
  • Thread starter Thread starter justa18unlv
    Physics
justa18unlv
To all,
So i"m studying physics for MCAT and I'm on solids sections, specifically on elastic properties of solids, I kind of get it but there is a problem I do not understand. The problem is:
A 2.5-kilogram (kg) mass is attached to one end of a sample of artery with 0.05 centimeter (cm) radius and 15 millimeter (mm) length. The other end of the artery sample is secured to a rigid support. Determine the elongation of the artery sample Y= 1x10^8 Nm^2.
Mostly I'm having a problem with determining which equation to use for this example, could someone help me out and maybe give me guidelines to what I should look for so I know which equations or theorems to use.
Thank you,
Justina
Welcome to PF!
Hi Justina! Welcome to PF! :wink:
justa18unlv said:
… Determine the elongation of the artery sample Y= 1x10^8 Nm^2.
Mostly I'm having a problem with determining which equation to use for this example …
I assume Y is Young's modulus?
Then what equation do you know involving Young's modulus? :smile:
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
