Why Is the Mean Speed of Gas Molecules Higher Than the Most Probable Speed?
  • Thread starter Thread starter nbasma20
    Mean Speed
nbasma20
Why does the mean speed of gas molecules exceed the most probable speed
under identical conditions?
N/A
Here's a simple analogous example: Imagine you have a die, but the numbers painted on the faces are {1,2,2,2,5,6}. Now I roll the die:
What is the most probable outcome (or the mode)? It's clearly 2.
What is the mean outcome? It's (1+2+2+2+5+6)/6=3.
The mean is greater than the mode because, while most of the faces of the die have small numbers, there are some with very big numbers that drag the mean up.
Now what does the distribution of speeds of gas molecules look like?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
