genneth said:
Expressing interacting systems as non-interacting ones is the basis of the entire field of condensed matter. However, it is not true that it's *always* possible.
I'm quite willing to accept that it may not be always true. But I can't think of a convincing argument either way.
In particular, the partition function can't have zeros at the origin, and thus it seems you could always factor it the way I suggested. So what are these seemingly non-interacting quasi-particle states? Even if it doesn't work for some reason I am missing, it is still not clear to me what it means when it
does work (and it isn't just linear combinations of single particle states).
genneth said:
For example, multiple spinless, massive particles with mutual Coulomb repulsion.
Can you give me a specific Hamiltonian to play with? I think I need to convince myself of this. Thank you for pointing this out.
Would it be something like this? (written in the position basis)
H = \int \epsilon \ a^\dagger(r_1) a(r_1) \ d^3 r_1 + \frac{1}{2} \int \frac{A}{|r_1 - r_2|} (a^\dagger(r_1) a^\dagger(r_2) a(r_1) a(r_2) + a^\dagger(r_2) a^\dagger(r_1) a(r_2) a(r_1)) \ d^3 r_1 \ d^3 r_2
Does the problem still arise when considering just a finite number of locations (like on a couple lattice positions)? That would make it a bit easier for me to conceptualize and play with.
genneth said:
For the specific case that you have stated, it is possible, and does indeed give a nice answer; but you could have seen that without doing the statistical mechanics --- just changes basis for the hamiltonian itself (notice that it is a quadratic form, so diagonalise it).
Yes, I guess I made the example too simple.
Add a repulsion term, and now we have:
H = \epsilon c_1^\dagger c_1 + \epsilon c_2^\dagger c_2 + t (c_2^\dagger c_1 + c_1^\dagger c_2) + A (c_1^\dagger c_2^\dagger c_1 c_2 + c_2^\dagger c_1^\dagger c_2 c_1)
Maybe again this is simple, but I don't see how to put this in the form:
H = \sum_i \epsilon_i b_i^\dagger b_i
with just a simple basis change. Yet the factorization above still holds. What are these non-interacting states: what do they mean physically? and how are they related to the original creation operators?
