Measure Theory-Lebesgue Measurable
  • Thread starter Thread starter WannaBe22
    Measurable Measure
WannaBe22
Let A \subseteq R be a Lebesgue-Measurable set. Prove that if the Lebesgue measure of A is less than infinity , then the function f(x) = \lambda(A \cap (-\infty,x)) is continous.
I'm really confused about the definition of \lambda (A) where \lambda is the Lebesgue-measure...I've tried taking an \epsilon >0 and choosing some \delta >0 for which if |x-x_0 | < \delta then |f(x)-f(x_0)| <\epsilon but I don't think this is the point...
I'll be delighted to get some guidance
Thanks !
Intuitively, f(x) is the measure of the portion of A "left of x". So if x < x', can you interpret f(x') - f(x) in terms of measures?
Intuitively, f(x')- f(x) is measure of the portion of A between x and x' ... Intuitively , this whole thing seems quite trivial...But when I try to get to the formal aspect of the soloution (as seen in "The attempt at a solution" part) , everything messes out... How can I make the intuition more formal ?
I really hope you'll be able to help me
Thanks !
Here are two hints:
1. Given that intuitive description of f(x') - f(x), try to come up with an upper bound for f(x') - f(x) in terms of x' - x. This is what you need to prove continuity. (What property of A would give the largest possible value for f(x') - f(x)?)
2. The fact that \lambda(A) < \infty is irrelevant to the continuity of f; you need it merely to define f.
What is f(x)-f(x0)?
Hint: you must use that if A\subseteq B and if those two sets have finite measure, then \lambda(B\setminus A)=\lambda(B)-\lambda(A).
Thanks a lot! your guidance was very helpful!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
