Measurement of Temperature question.
A student is tasked with estimating the temperature of ice cream using a mercury thermometer that only measures from 0 to 100 degrees Celsius. Since ice cream is typically below 0 degrees, the discussion explores methods to determine its temperature, such as placing it in a closed system with melted ice cream to reach thermal equilibrium. Participants suggest measuring the initial temperature of the melted ice cream and using it to calculate the final temperature of the combined system. The conversation emphasizes the importance of understanding the concept of thermal equilibrium and using known values to find unknown temperatures. Ultimately, the student gains clarity on how to approach the problem mathematically.
lionely
A mercury thermometer with only the 0 degree Celsius and 100 degree Celsius markings on it was given to a student, and the student was asked to use it to estimate the temperature of a block of ice cream.
I'm not sure, because the scale stops at 0 and mostly likely the temperature of ice cream is below 0. What should I do?
Can someone give me a hint please?
What if we put the ice-cream in a closed system and measure the temperature change in the system?
Oh like if we put it in a plastic dish that was let's say 50 degree celcius and then we put the ice cream in and then it dropped to 10 then the temperature of the ice cream is -40?
Or melt a bowl of ice cream until its temperature is 10C, then place the frozen ice cream in the melted ice cream and allow it to reach thermal equilibrium. I would also ensure the mass of both are equal.
Oh Thank you!
I think it would be something like:
T_{final, system}=(T_{initial, melted}+T_{initial, frozen})/2
I'm sorry I don't really understand that equation why would you divide it by 2?
Dividing it by two averages the temperatures of the melted and frozen.
Oh I see, sorry xD. So from if the melted was 10C and the frozen was -30C
then final temp would be (10C + (-30C))/2= -10C ?
Yes, and if that were the case you would still not be able read it on the thermometer unless the final temperature of the system>0. So if you get a reading of zero, you may have to further increase the temperature of the melted ice cream. Does that make sense?
So for the student to read it the ice cream must melt until about, 20C
I'm going to change my assumption and assume the frozen is about -15C
so it would be
(20C -15)/2 = 2.5C
But is it right it to make such an assumption?
You don't have to make an assumption. For example, you measure the initial temperature of the melted ice cream to be
T_{initial, melted}=10.
You then combine the melted ice cream with the frozen ice cream and allow the system to reach equilibrium at which point you will measure
T_{final, system}
Can you now see how to determine the initial temperature of the frozen? Btw, this is assuming a closed system and is merely an approximation..
Oh yes I see how you would get the initial frozen simple mathematics stupid me. Just
find the unknown with the two known. I think I fully understand now.
