Measuring Capacitance using a basic Multimeter
32 replies · 4K views
ARoyC
Is there any way to measure the capacitance of a capacitor indirectly using a multimeter that does not have the option to measure capacitance directly?
There may be some ways, but it will depend on the value range of capacitance and what other equipment do you have available (like a signal generator)...
Also -- to what accuracy?
What capacitance range? Have you measured the input resistance of your DVM for DC Voltage measurements in the 10-ish volt range?
The capacitance range is from about 1microfarad to 4000microfarad.
Sorry, I did not understand your second question.
Will this method work?
I can construct a circuit using a battery, a thin wire, a resistor and a capacitor. I can calculate the EMF of the battery and the resistance using the multimeter. Then I can use a stopwatch to measure the time required for the voltage drop across the capacitor to become half of the EMF. Then I can measure the capacitance using the RC Circuit equation, V_c = EMF(1-e^(-t/RC)). There will be some error for sure. But is it possible?
ARoyC said:
The capacitance range is from about 1microohm to 4000microohm.
You mean uF, right?
The input resistance of your DVM will be in parallel with the capacitor voltage that you are measuring, so will tend to discharge the cap more than with just an external resistance. If your DVM has 1MegOhm input impedance and you are using kiloOhm resistors in your circuit, then it will not cause much error. But for smaller values of capacitance, you will need to use larger values of resistance to get discharge/charge behaviors that you can observe on human timescales, so the DVM input resistance may become a factor in your RC time constant calculations.
You will need to include a switch in your circuit, and open or close it to measure the discharge or charging time constant. The resistor goes in a different place for each one of those test circuits.
Can you upload a sketch of the circuit that you propose using? And can you say what resistor values you should use for each decade of capacitor values?
Very sorry, yes. Microfarad. I corrected it.
Oh, okay. Understood. I have to check out the multimeter then.
Thanks for reminding me of the switch. Yes, I need a switch. Why the resistor will go to a different place?
No, I am not sure about the resistor values. But I think that those should be quite high. The circuit should be a simple series circuit with all the components in series. I can upload a picture if it helps.
Yes, it would be good to see a sketch of the circuit that you have in mind.
The resistor would go in different places depending on whether you are measuring the discharge time or the charging time. If you are measuring the time it takes to charge the cap up, you would connect these in series: Battery, switch, resistor, capacitor. You close the switch and measure the time to reach 63% (or whatever percentage you want to use for your RC formula) of the battery voltage.
If you want to measure discharge time, you would connect the resistor and cap in parallel, and then connect those to the battery through the switch. You would close the switch and let the cap charge up (relatively quickly, depending on the output resistance of the battery), and then open the switch and measure the time it takes to fall to 37% (or whatever) of the battery voltage.
If you want to get fancy, you could figure out how to use a single pole double throw (break before make) switch to be able to measure both the charge and discharge times... :smile:
You could avoid external circuitry by charging the cap with a resistance measurement, then measuring the rate the voltage falls during a voltage measurement.
Interesting! That will limit the range of capacitances that can be measured, but it's a great simplification. :smile:
Two other ways come to mind.
  1. If you have some known capacitors you can use a battery to charge one of them to battery V and then connect it to the unknown cap and then measure the resultant voltage.
  2. If you have (or can make) a constant current supply then the increase in capacitor voltage will be linear in time. The constant slope of V vs t will give you C pretty accurately
But the method of directly finding the decay time with known resistance is probably easiest and best for your 10% target accuracy. Of course if you really wanted accuracy there are null bridge methods and oscillator frequency methods
BTW, I hope this is not a misplaced homework assignment in the EE forum, because we have solved it for you multiple times over. If it is a homework problem, at least give attribution to this thread in your solution that you send to your class.
A good linesman with a moving coil ohmmeter, would measure the resistance of a twisted pair line that was open circuit. Judging by the “kick”, how close the pointer got to zero ohms and how quickly it fell back towards infinity, they could judge the length of the cable. It would tell them roughly how far to go when searching for a break in a line.
In effect that was a dynamic capacitance measurement, a measurement that would once have been done in a lab with a ballistic galvanometer.
Sadly, in my experience even multimeters capable of measuring capacitance rarely work as expected. Tried three and they were all capricious and inconsistent, sometimes giving reasonable numbers, sometimes wrong ones, sometimes none. Same meters never failed me while measuring resistance and voltage, so I don't think it was a matter of misuse or bad contacts.
Well, I did that way back in mF range for finding functional caps for motherboards (amongst disassembled caps from motherboards).
The speed the voltage climbed told if the capacity is still in range, and after some 'rest' time by the remaining voltage I could tell whether the leakage is still OK.
Well, not really a measurement, especially with that response time of the DMM I had: but just recently I've seen one of my re-capped boards sold as 'vintage, working' o0)
One other tip -- see if you can put your DVM into "Range Hold" mode so that it does not try to autorange during the measurement of the increasing or decreasing voltage values. If it keeps changing ranges during the voltage changes, that will slow down the measurements. Also, some DVMs have a bargraph displat at the bottom of the LCD, which is handy when trying to see the changing voltage intuitively.
Sorry for being so late. I was loaded with college assignments. I am attaching the circuit diagram. Please forgive my disastrous drawing.
Could you please explain a bit, if possible?
That works for measuring the charging time constant if you put a SPST switch to the left of the battery. :smile:
Those are really interesting methods. Thanks for the insight.
Actually, this is not a homework problem. But another homework problem inspired me to think about this.
I am not sure that I could understand this. Could you please explain?
Okay, I will look into this.
And for a circuit like I described using a SPDT switch (break-before-make) to alternately measure the charge and discharge times, you could use something like this (with better R and C values, and you don't need the Ammeter so just short it out):
https://rsdacademy.net/textbooks/dcelectronics/Part5/CapacitorDemonstrationCircuit.png
Yes, sorry. I have to add a switch. Then by calculating the time constant, won't it be possible to calculate the capacitance?
ARoyC said:
Do I have to do the discharge to recheck my calculated value?
You need to fully discharge the capacitor before you measure the charging time constant waveform. And similarly, you need to fully charge the cap before you measure the discharge time constant waveform.
Alternately, you need to use the starting voltage for either one in your calculation, and not just assume the capacitor starts at 0V and Vbatt for the two transients. Does that make sense?
Why won't the capacitor start at 0V and V_batt if I discharge it fully?
I don't understand the question. In the circuit you posted, if you put a switch in series with the battery, the first time you close the switch you will be able to measure the charging time constant. But disconnecting the SPST switch does nothing to discharge the cap, so unless you have some other way to discharge the cap (like the SPDT circuit), you only get to do the experiment once.
Yes, that I understand. I need to construct the circuit in such a way so that I can discharge it. And the SPDT circuit is needed for it. Probably I asked the last question due to a misunderstanding.
Thank you so much for the solution!
