Measuring classical object to arbitrary precision
The discussion revolves around the confusion regarding the measurement of classical objects, like a baseball, in contrast to quantum objects, which are subject to inherent uncertainty. It questions how we achieve arbitrary precision in measuring classical objects when their edges, composed of atoms, also exhibit quantum behavior. Participants clarify that while classical measurements seem precise, they do not violate the Heisenberg uncertainty principle, as these measurements exist in a theoretical framework rather than practical reality. The conversation highlights the distinction between idealized classical scenarios and the complexities introduced by quantum mechanics. Ultimately, it emphasizes that true precision in measurement cannot escape the influence of quantum uncertainty.
YummyFur
This has been nagging me in the background of my mind for many years and I've decided to get it sorted.
I note that I'm not sure if this should be in the classical or quantum forum.
I have heard it mentioned by many and often when referring to the inherent uncertainty when measuring quantum objects, that unlike classical objects which can be measured to arbitrary precision, quantum objects...etc
It's this reference to the apparent precision that puzzles me. They will say, first how as we zero in on the momentum we become more fuzzy about position of a quantum object, unlike say a car or a baseball which we are told can be measured to this so called arbitrary precision.
My question is, how do we measure this mythical classical baseball that avoids the quantum object problems.
Do we measure from the centre of the baseball? Where exactly is that, or the leading edge of the baseball, again, where is that because it seems to me that the edge of the baseball is a quantum object.
Why is the edge of the baseball, the very leading atom, the atom that is most furthest forward of the rest of the baseball any different to a single atom without the rest of the baseball.
And further, when we are going for this arbitrary precision, then do we not have to use a quantum object to measure. If the baseball is set up to break a beam of photons, then again the photons just bring back the quantum uncertainty if we try to approach this arbitrary precision.
YummyFur said:
My question is, how to we measure this mythical classical baseball that avoids the quantum object problems.
You can't avoid it, but you could in a make-believe classical world. I don't think anybody is saying that in the real world you can measure the position and momentum of a baseball bat to a degree of accuracy that violates the Heisenberg uncertainty principle.
But then again, in the make-believe classical world, you can in principle measure everything accurately..., so the statement about the bat could just as well be made about some kind of a make-believe "classical atom".
Ah, ok that makes sense. I get it now. It's a principle sort of like a perfect thought experiment.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
Hello! I am generating electrons from a 3D gaussian source. The electrons all have the same energy, but the direction is isotropic. The electron source is in between 2 plates that act as a capacitor, and one of them acts as a time of flight (tof) detector. I know the voltage on the plates very well, and I want to extract the center of the gaussian distribution (in one direction only), by measuring the tof of many electrons. So the uncertainty on the position is given by the tof uncertainty...
