MHB What is the efficiency of the energy conversion in the cannon bore?
The discussion focuses on calculating the mechanical equivalent of heat based on Rumford's observation of a horse turning a cannon bore, which raised the temperature of water significantly. The conversion of units to SI and the application of the formula Q = mcΔT led to a calculated specific heat value of 5.468 cal/g°C, equating to approximately 5.48 J/cal. Participants clarified the importance of using the correct units, particularly distinguishing between pound-force and pound-mass, and discussed the potential for energy loss in the system. Ultimately, the efficiency of energy conversion in this scenario was determined to be around 76.5%. This highlights the relationship between work done and heat generated in mechanical systems.
Fantini
MHB
The problem:
Rumford observed that when one horse turned a cannon bore for about 2.5 hr the temperature of 27 lb of water that was initially ice cold (i.e., near 0°C) rose to near boiling hot (i.e., near 100°C). Given that one horsepower is 33,000 ft-lb;min, that 1 kg weighs 2.2 lb, and that 1 in. = 2.54 cm, what is the mechanical equivalent of heat in joules per calorie implied by these rough numbers?
I converted all of the units to SI and equated $Q = mc \Delta T$, trusting that we have to find is $c$. The numeric value I found for $c$ is 5.468 cal/g°C. The answer is 5.48 J/cal.
The numbers match, but I'm not sure I'm understanding the concept behind what I'm doing. The mechanical equivalent of heat is how much work you have to perform on the system (or by the system) to generate the same temperature difference due to heat. How would I compute that in this case?
Mathematics news on Phys.org
Fantini said:
The problem:
The units are different, so if the numbers are close, that is merely coincidence.
It means we're talking about different quantities.
Btw, the unit of your horsepower should be $\text{ft}\cdot\text{lbf}/\text{min}$, where $1\text{ lbf} = 1 \text{ lb} \cdot g =1 \text{ lb} \cdot 9.81 \frac{\text{m}}{\text{s}^2}$.
The formula to calculate the work of the horse is:
$$W=P\cdot t$$
where W is work, P is power, and t is time.
From $W=P\cdot t$ and the proper conversions, we get the work done by the horse in joules.
From $Q=mc\Delta T$, we get the same energy in calories.
Btw, the value of $c$ was apparently once defined as $1 \text{ cal}/(\text{g}\cdot\text{°C})$.
Where did you get $5.468 \text{ cal}/(\text{g}\cdot\text{°C})$ from?
Set them equal to each other, and we can calculate the ratio between joules and calories, which should come out as a constant that depends on which definition for calorie we use. In all cases it is:
$$4.182 \lessapprox \frac{\text{cal}}{\text{J}} \lessapprox 4.204$$
What I did was convert $27$ lb to $kg$, finding $m = 27/2.2 \text{ kg} = 27/2.2 \cdot 10^3 \text{ g}$. I used the same formula you did for energy, finding $$W = \frac{33000 \text{ ft-lb}/\text{min}}{0.7376 \text{ ft-lb}/\text{J}} \cdot 150 \text{ min} = \frac{33000 \cdot 150}{0.7376} \text{ J}.$$ Then $Q=mc \Delta T$ implies $$c = \frac{Q}{m \Delta T} = \frac{33000 \cdot 150}{0.7376} \cdot \frac{1}{\frac{27}{2.2} \cdot 10^3} \cdot \frac{1}{100} = 5.468 \frac{\text{ J}}{\text{g} \cdot {}^{\circ} \text{C}}.$$
Edit: From the computations above I see that it's $5.468$ Joules per gram centimeters.
Does this mean that to arrive that the desired answer we divide by $$c_{\text{water}} = 1 \frac{\text{ cal}}{\text{g} \cdot {}^{\circ} \text{C}}$$ to arrive at the mechanical equivalent?
That should be $\text{lbf}$ instead of $\text{lb}$. (Worried)
The difference is a factor of $9.81$ and a different unit.
$1 \text{ lbf}$ is the weight of $1 \text{ lb}$, which is the force with which the Earth pulls on the mass. (Nerd)You're only getting away with it, because the units cancel. (Whew)
Yes. (Nod)
More accurately, you're using the mechanical equivalent to approximate the ratio between joule and calorie.
We can expect some energy to "leak" away, which is why your value is higher than the defined value. (Nerd)
Then the book is wrong, as I copied verbatim. (Worried) But I understand your point now.
You mean that we measure additional energy that "leaked" from somewhere else, hence why the value is higher?
The power the horse provides makes the temperature of the water rise, but it also makes the area around the water rise, which leaks away without use to us.
More specifically, the efficiency of the energy conversion in the cannon bore is:
$$\text{efficiency} = \frac{\text{Useful output energy}}{\text{Total input energy}}
=\frac{Q}{W} = \frac{4.184}{5.468} = 76.5 \%$$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
