How Does Angular Velocity Influence Particle Motion in Rotational Dynamics?
In summary, the conversation discusses a rotating particle in a tube and its radial distance and normal force over time. The equation in question is found to be equal to 0 due to the use of curvilinear coordinates and the absence of a radial force in a fixed coordinate system. Using a rotating coordinate system results in the same equation with the centrifugal and Coriolis effects balancing the tangential force.
ensten
A particle of mass m is inside a long, narrow tube which rotates
a constant angular velocity ω in the horizontal plane. (This means that you see the tube
from the top of the figure and not from the side.) At time t = 0 is the particle on the radial distance a from the rotational axis and the radial velocity is zero. Then begins the slide without friction. Determine the particle radial distance from the rotation axis and the horizontal normal force of the particle from the tube functions
of the time!Why is equation (10) found in this solution https://dl.dropboxusercontent.com/u/12645136/Losningar.pdf equal to 0?
If the particle moves from the center outwards isn't a force acting upon it in the radial direction? Hence giving it an acceleration in the same direction?
I will write this in English since it is public, PM me if you would perfer an explanation in Swedish:
No, assuming you solve this in a fixed coordinate system, there is no force acting in the radial direction (there simply is nothing to provide such a force). The reason you will have acceleration in the radial direction is that you use curvilinear coordinates, resulting in that a velocity in the tangential direction is translated into a radial component as the particle moves. This is described by the ##r\dot\theta^2## term in the radial equation.
If you instead chose to use a rotating coordinate system, the very same term will be provided by the centrifugal effect and you end up with the same equation. The tangential force will now be balanced by the Coriolis effect.
Related to How Does Angular Velocity Influence Particle Motion in Rotational Dynamics?
1. What is circular motion in mechanics?
Circular motion in mechanics refers to the movement of an object along a circular path at a constant speed. This type of motion is characterized by a centripetal force, which acts towards the center of the circle, and a tangential velocity, which is perpendicular to the centripetal force.
2. How is circular motion different from linear motion?
Circular motion is different from linear motion in that the direction of the object's velocity is constantly changing in circular motion, while it remains constant in linear motion. Additionally, circular motion requires a centripetal force to maintain the circular path, while linear motion does not.
3. What is the relationship between circular motion and acceleration?
In circular motion, the acceleration is directed towards the center of the circle and is always perpendicular to the velocity. This acceleration is known as centripetal acceleration and its magnitude is equal to v^2/r, where v is the tangential velocity and r is the radius of the circle.
4. How is angular velocity related to circular motion?
Angular velocity is a measure of the rate at which an object is rotating. In circular motion, the angular velocity is constant, but the tangential velocity varies depending on the distance from the center of the circle. The relationship between angular velocity and tangential velocity is given by v = ωr, where ω is the angular velocity and r is the radius of the circle.
5. What are some real-life examples of circular motion?
Some examples of circular motion in everyday life include the rotation of a Ferris wheel, the motion of a car around a circular track, the orbit of planets around the sun, and the motion of a fan blade. Circular motion is also seen in the rotation of gears, spinning tops, and the motion of a swinging pendulum.
