MHB Friction Mechanics: Solving for Block's Speed at Point A
To determine the speed of a wooden block sliding down a rough slope, the block's mass is 3.5 kg, and it initially moves up at 20 m/s before coming to rest 25 m up the slope, which is inclined at 29 degrees. The coefficient of friction was calculated to be 0.554, leading to an acceleration of -8 m/s². Using the equation v² = u² + 2as, the acceleration was further analyzed, resulting in a recalculated coefficient of friction of 0.36. The discussion emphasizes the need for accurate calculations to find the block's speed at point A on its return. The focus remains on solving the mechanics of motion under frictional forces.
Shah 72
MHB
A wooden block of mass 3.5kg is sliding up a rough slope and passes a point A with speed 20m/s. The slope is at 29 degree to the horizontal. The block comes to rest 25m up the slope. Find its speed as it passes point A on the way down.
I calculated coefficient of friction = 0.554.
U=20m/s v= 0 and s= 25m.
By using v^2= u^2+2as, I got a= -8m/s^2.
I can't calculate after this.
Pls help
Mathematics news on Phys.org
upslope …
$a = \dfrac{0^2-20^2}{50} = -8 \, m/s^2 = -10[\sin(29)+\mu\cos(29)] \implies \mu = 0.36$
try again …
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
