Melting ice block on an inclined plane?
The discussion revolves around a physics problem involving a melting ice block sliding down an inclined plane with a rough surface. The ice block starts at 3 kg and decelerates at -0.2 m/s² for every 0.2 kg it loses, beginning with an acceleration of 0.7 m/s². Participants clarify that as the block melts, its acceleration decreases proportionally, and they seek to determine the mass when the acceleration reaches 0 m/s². The conversation highlights the relationship between gravitational force, friction, and the resultant force when acceleration is zero. The complexity arises from the changing mass and acceleration, suggesting that the coefficient of friction cannot remain constant throughout the process.
NotANumber
Hello all...
Help... :confused:
my teacher gave us this question and...
no matter how I approach this question, I just can't solve it...
The question asks...
an ice block melts and slides down a plane of rough surface..
The mass of the ice block starts at 3 kg, and its mass decreases as it melts..
The ice block decelerates at -0.2 m/s^2 per 0.2 kg mass starting at an acceleration of 0.7 m/s^2... (the incline of the plane is 20 degrees, so the angle between the Fgravity and Fperpendicular is 20 degrees as well, Fperpendicular = Fpull, that I know)
and the question asks me to find the mass of the melting ice block at 0m/s^2 and as well the friction acting on the ice block (assumed to be constant)
I think I kinda know how to do this (I can do mass on an inclined plane with u coefficient), but my teacher doesn't like giving us u... plus I just kinda can't think my way around this melting mass with an shifting acceleration thing...
Help?
I think the wording of this question could be a little clearer. Particularly, exactly what is meant by "decelerates at -0.2m/s/s per 0.2kg"
I take it to mean that the block, initial mass 3kg, starts slipping down the plane and has an initial acceleration of 0.7m/s/s down the plane. It is melting, and for every 0.2kg of mass it loses, the acceleration reduces by 0.2m/s/s.
So when it is 2.8kg the acceleration is 0.5m/s/s, when it is 2.6kg the acceleration is 0.3m/s/s and so on.
So what is the mass when the acceleration is 0m/s/s
When the acceleration is zero, what do you know about the resultant force on the block?
If you know the component of the weight down the slope, you can find the frictional force required to give zero acceleration.
I imagine the reason your teacher does not want to discuss the coefficient of friction, is that in order for this all to happen as described, its value cannot remain constant.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
