Method of undetermined coefficients
2 replies · 3K views
s7b
Hi,
When using the method of undetermined coefficients to solve
2y'' + y' = cos(2x) + 4x + 1
I did it term by term. I figured out the first yp1 for the cos(2x). I'm just not sure what to "guess" as to the form of the yp2 for 4x+1
Does anyone know what to use as the guess?
when you solved the auxilary equation if one root was 0, then for a polynomial, the particular integral would be a degree higher. For example if you solved and 0 was a root of the aux. eq'n. and the right side was ax+b, then the PI would be Ax^2+Bx+C
It is easy to know what to guess.
[D^2+2^2]cos(2x)=0
[D^2](4x+1)=0
Guess the solution to lcm{[2D^2+D],[D^2],[D^2+2^2]}=[D^2][2D+1][D^2+2^2]
