Microbial contaminants in water distillation
  • Thread starter Thread starter fandangou
    Distillation Water
Boiling water to purify it from microbial contaminants raises important considerations. When water is boiled, most vegetative cells of human pathogens are killed, but spores from certain organisms can survive and may aerosolize, potentially condensing in the collected vapor. This poses a risk, especially with pathogens like Bacillus anthracis. While the vapor itself is generally expected to be free of microbes, the possibility of aerosolized spores being carried along must be acknowledged. Regarding the impact of microbes on water properties, there is a lack of specific studies addressing how microbial presence affects factors like ebullioscopic constant, heat capacity, and enthalpy of vaporization. The consensus is that empirical data may be necessary for deeper insights, as pure water is typically used in industrial processes to avoid complications from organic materials.
fandangou
Hello all,
I have a few questions regarding purification of water of microbial contaminants by boiling.
1. If water containing microbial contamination is boiled, and the vapor is collected, is the condensed vapor going to be free of microbes? I would think so because if the microbes don't die during boiling, they probably aren't going to be boiled into vapor along with water. But am I missing any pieces? Would microbes somehow find a way to stay onto the water vapor particles?
2. Are there any studies that discuss how microbes in water affect its properties? In other words, what is the ebullioscopic constant of microbes, how microbes affect heat capacity and enthalpy of vaporization of water, etc? I couldn't find anything on this.
Thank you.
Chemistry news on Phys.org
1. A single microbe is many orders of magnitude larger than a water molecule. After all, microbes are composed of water and other organic compounds.
2. Like most living things, microbes are more water than anything else. I don't think you are going to find any physical data on water chock a block with microbes because only pure water is used in heat generation or manufacturing processes. For instance, if the feed water for a boiler contained a sizable fraction of organic material, the boiler would become clogged with the scale formed from this material and possible fail.
fandangou said:
Hello all,
Thank you.
1. It is entirely possible that microbes become aerosolised and carried upward with the vapour (and end up condensing on whatever you're collecting the vapour on or in). However, practically all vegetative cells of human pathogens die when exposed to boiling temperatures under conditions of normal atmospheric pressure. The exception is with spore-forming organisms, that can survive ordinary boiling very easily. The spores can be borne aloft in the vapour and condense, as I've already mentioned. The spores can then revive to become active vegetative cells when they're cooled. If you're boiling a suspension of highly pathogenic Bacillus anthracis, for instance, this is a real concern.
The vegetative cells of some extremophiles can survive boiling, but these are not usually considered human pathogens (they're free-living saprophytes for the most part).
The concern with aerosolisation is the main reason why microbiology laboratories working with human pathogens use biosafety cabinets.
2. I am not aware of any data, per se, for microbial suspensions. I agree with SteamKing's answer. If you really want data, I guess you have to take the empirical approach.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
