Is Eating Only Microwave Food Unhealthy?
In summary, the article claims that microwaving can be unhealthy, especially if you're eating pre-packaged meals that are high in salt and saturated fat. It also suggests that protein quality might be higher in microwaved meats than in conventionally cooked meats.
Tsunami
91
Not sure if this is the right forum for this question (maybe I need some microwave theorists instead?) , but:
a friend of mine was telling me about an article she read about microwave food being unhealthy for you. Apparently, living off a diet of microwave for too long, even though you are getting all the nutrients you need, is still very unhealthy.
Can somebody back this up or disprove with scientific arguments? Thank you.
Biology news on Phys.org
Do you mean eating microwave food that has been pre-packaged and usually found in th frozen section or do you mean just using the microwave to heat up one's food. About the microwave dinners, they are always very high in sodium and usaully high in saturated fat, which is an unhealthy combination. I'm not sure about the actual microwave making the food unhealthy. Maybe someone can help?
In microwave cooking, the wavelength (12cm) chosen was one that is found to excite (increases kinetic energy) water molecules.
So as the microwaves pass thru food in the oven, their energy is converted to heat. When you pop, popcorn in a microwave, it is heating the water in the corn kernel to a temperature where it bursts the seed coat. When you insulate your food (leaving the husk on sweet corn, or wrapping dehusked sweetcorn with paper towels) you will find that it cooks faster in the microwave.
So try and heat up some ordinary dry paper towels (nothing else) in the microwave oven and see what happens.
I don't know if there have been any rigorous studies to explore whether microwaves (wavelength of 12cm) alter the chemistry of other molecules in food. Perhaps someone else can help there..
What does this do? I've been warned against heating unusual things in the microwave, as it can be a fire risk.
There are some concerns that plastics and other materials used in packaging of microwave foods may be absorbed into the food that we eat. The FDA says there is no need for concern. They also say...
Microwave-safe plastic wrap should be placed loosely over food so that steam can escape, and should not directly touch your food. "Some plastic wraps have labels indicating that there should be a one-inch or greater space between the plastic and the food during microwave heating," Machuga says.
Always read directions, but generally, microwave-safe plastic wraps, wax paper, cooking bags, parchment paper, and white microwave-safe paper towels are safe to use. Covering food helps protect against contamination, keeps moisture in, and allows food to cook evenly. Never use plastic storage bags, grocery bags, newspapers, or aluminum foil in the microwave.
On one hand they say there is nothing to be concerned about and on the other they say not to use certain plastics and not to let plastic touch the food. There are probably regulations on what types of plastics can be used for use in a microwave. At one time there might not have been.
http://www.fda.gov/fdac/features/2002/602_plastic.html
Other than the plastics issue, I really don't know of any reason why microwaving would be a problem. Are there any vitamins or other nutrients that are broken down by microwaves? That's about the only other thing I could think of that might be an issue, but I don't know the answer to that question.
I don't think it's the microwaving itself, or the containers which are the problem. All the recent health concerns here have just been regarding the ingredients. Loads of ready-meals have really high salt contents, and lots of saturated fat.
You'll find a lot of propaganda on the web, making all manner of wild claims. I did manage to find one site that seemed reliable - it's run by the Australian government, so their info is presumably legit.
It seems the main concern was that vitamins, especially B vitamins, can be lost when you cook meat in the microwave. This was found to occur in studies, but is probably just due to meat being cooked in more water than is necessary. It is recommended that you drain your meat of any excess water before microwaving, in which case the vitamin content remains the same. Microwaving vegetables, on the other hand, seems to actually increase vitamin retention over conventional forms of cooking. This site also suggests that protein quality might be higher in microwaved meats than in conventionally cooked meats, because the decreased cooking time results in less oxidation. Here is the site:
http://www.foodscience.afisc.csiro.au/micwave1.htm
Paper is not unusual. It is often used to wrap around food that you are heating.
What happens when you heat paper in a microwave? Although the moisture in paper ranges between 4-10%, the temperature change upon exposing to microwaves in an oven, will be slight. You probably won't notice any difference.
You may want to try this experiment again, after moistening the paper towel.
The World Heath Organization has an excellent information sheet on microwave ovens and health.
An exerpt "Food cooked in a microwave oven is as safe, and has the same nutrient value, as food cooked in a conventional oven. The main difference between these two methods of cooking is that microwave energy penetrates deeper into the food and reduces the time for heat to be conducted throughout the food, thus reducing the overall cooking time."
CSIRO are very good research institution that do research in these genres, food, agriculture and biotech. I am a man for the good old wood fire oven, but having neighbours one has to make a compromise. Generally I have found "taste" to be different from traditional methods of cooking and conventional (stove, oven..). Obviously food is being cooked so there is chemical change and due to that one can assume a change in the nutrient content and nature, taste is also a pretty good indicator as our tastebuds react to several macronutrients and their relative concentrations would affect the general sensation which to my observation was the case.
Although there are several loopholes in that observation, I would opt for not using the microwave to cook food but only to heat foods just for the taste factor. Evolution has made us like certain foods and dislike others, I go by the tongue rather than what is taught and told about nutrients, so phrasing it like one would hear in iron chef "let the tongue be your guide".
So, in summary:
1) Pre-made microwave meals are generally less healthy, and a diet based on these meals will have an unhealthy effect on your body.
2) Certain plastics used to cover microwave meals can contaminate these meals when in direct contact with the meal.
3) If sufficiently covered and nutrients aren't lost through loss of vapour, traditional cooking and microwave cooking lead to comparably healthy meals.
4) Taste is also a good determinant for healthy food, and microwave food is simply less tasteful.
Leading to more questions:
2) I've the habit to cover my plate with another plate. Is there any reason why I shouldn't do this? It's much more economical/ecological not to have to throw away plastic coverage.
4) I agree, although I think that heating food that has been cooked beforehand, has the same problem. That's where the phenomenon 'rubber chicken' comes from.
Evidence has been found of microwave cooking destroying more nutrients than other methods, due to higher temperatures reached.
http://www.newscientist.com/article.ns?id=mg18024182.000
Of course boiling vegetables will also lose nutrients, and it's difficult to be sure that the researchers compared like with like, see:
http://www.newscientist.com/article.ns?id=mg18024214.600
I think the overall conclusion is that if you want to retain nutrients then steaming is best.
Hmm...if they're trying to compare 5 min in the microwave to 3.5 min steaming, I don't know how you can draw any conclusion at all! I tend to agree with the second comment there, that it might be more of an indicator that the best way to retain nutrients is to not overcook your food. I've never known the microwave to require more time than conventional cooking!
FAQ: Is Eating Only Microwave Food Unhealthy?
1. Is microwaving food bad for your health?
There is no conclusive evidence that microwaving food is bad for your health. Microwaves use radiation to heat food, but this radiation is non-ionizing and does not have enough energy to damage DNA or cause cancer.
2. Does microwaving food destroy its nutrients?
Microwaving food can actually help retain nutrients better than other cooking methods. The quick cooking time and minimal use of water can prevent the loss of water-soluble vitamins. However, some nutrients, like vitamin C, may break down during the heating process.
3. Can microwaves cause cancer?
There is no evidence that microwaves cause cancer. As mentioned earlier, the radiation used in microwaves is non-ionizing and does not have enough energy to damage DNA. The FDA regulates the safety of microwave ovens and ensures that they do not emit harmful levels of radiation.
4. Is eating only microwave food unhealthy for weight loss?
The type of food you eat, rather than how it is cooked, is more important for weight loss. Microwaving food does not automatically make it unhealthy. It is still important to choose nutritious and balanced meals, even if they are cooked in a microwave.
5. Are there any health risks associated with microwaving plastic containers?
While some plastic containers may be labeled as microwave-safe, it is generally recommended to avoid microwaving food in plastic containers. When heated, plastic can release toxic chemicals into the food. It is safer to use glass or ceramic containers for microwaving food.
