Minimization Problem (using Projection)
Dwolfson
Minimize ||cos(2x) - f(x)|| where f(x) is a a function in the span of {(1,sin(x),cos(x)}
Where the inner produect is defined (1/pi)(integral from -pi to pi of f(x)g(x) dx)
I found f(x) to be zero. Is this correct I am uneasy about this solution.
My solution I took the inner product of cos(2x) with each of the elements of the set {(1,sin(x),cos(x)}
Knowing that the projection of cos(2x) onto this span would give me the smallest norm.
I found that the projection of cos(2x) onto this set is 0.. Because given this inner product definition cos(2x) is orthogonal to {(1,sin(x),cos(x)}.
I am uneasy about this answer because intuitively it does not seem that f(x)=0 would minimize the norm of ||cos(2x)-f(x)||
Thanks.
I think that's right! The integrals you have to do well known from the orthogonality of Fourier components.
If you draw the graphs on top of each other maybe it will be a bit more intuitive. It should be clear that 1 shouldn't overlap, since the average of cos(2x) is 0. As for sin and cos, the different periodicity means that for everywhere the functions agree, there is somewhere else half a phase later where they disagree just as much so they shouldn't overlap. Hope that makes a little sense...
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
