Minimum coefficient of static friction
10 replies · 10K views · last reply
emily081715
If the incline of the driveway is 19 ∘ from the horizontal, what must the minimum coefficient of static friction be between your shoes and the ice?
Fs=uN
Handwritten free-body diagram on lined paper for problem 10.80: an incline at 19 degrees with a block, axes x and y, and forces mg, N and fs labelled, followed by equations fs = uN, Fx = mg sin theta - fs, Fy = N - mg cos theta, u = fs/N, and g sin 19 / g cos 19 = 0.15.
i need help figuring out my error, i assumed that the N force was equal to mgcosθ and Fs was equal to mgsinθ. the masses must cancel out and following what is written on my paper, i got and answer of 0.15. this is incorrect and i need help finding out why
Degrees versus radians.
i don't understand?
emily081715 said:
i don't understand?
Did you plug the 19 degrees into the tan function of a calculator? It can probably be set to expect angles to be specified in degrees or radians, but you have to make sure you select the right one.
so my original answer was in my radians and i did 9.8 tan (19) in degrees and got 3.4 as the answer, is that to big?
Why the 9.8? g is not part of the coefficient.
well actually i know its incorrect
so just tan (19)
