Minimum speed of an object required to go round a circular loop.
To determine the minimum speed required for an object to complete a circular loop, the velocity at the top of the loop must be sufficient to maintain contact, calculated using the formula v = SQRT(g*r), where g is gravitational acceleration and r is the loop's radius. It's suggested that starting the object at the top of the loop and measuring its speed at the bottom can help establish the necessary entry speed, factoring in friction losses and a safety margin. For roller coasters, an elliptical or egg-shaped loop is recommended over a circular one to manage g-forces better, allowing for a smoother experience without excessive strain on passengers. This design helps maintain the necessary forces at the top while reducing the initial g-forces experienced during ascent. Overall, understanding the physics of motion and energy conservation is crucial for safe and effective loop designs.
supersingh
hey, how would you find the minimum speed of an object required to make it go around a circular loop?
If at all possible, put the object at the top of the loop and let it roll down. Measure its speed as it reaches the bottom of the loop, and that is the speed with which it will need to enter the loop, but you must then add whatever speed you expect to lose to friction, plus whatever safety margin you want.
BTW; if this is for a roller coaster, you're definitely going to want an eliptical loop that is NOT circular. Is that a workable solution for your application?
Why?
Due to friction? Neglecting friction, in theory, the potential energy at the top of the circular loop at most equals kinetic energy at the bottom of the loop.
A loop that is elongated vertically requires roughly the same velocities as a circular loop, but you can load fewer g's onto the car as it climbs, and more at the top where the turn is sharper. That way, you get the g-forces you need to keep the thing stuck to the rails at the top of the loop, without putting so many g's at the start as to break the necks of the human passengers.
Of course, if they paid in advance...
Oh, so you don't actually mean elliptical, but egg shaped. :smile:
Either one's good, but yes; egg-shaped is even better than elliptical.
If you are referring to the minimum velocity required to maintain contact within a loop (at the top most portion), then the you can find it typically with v = SQRT(g*r).
where,
v = velocity
g = gravitational accel.
r = radius of loop
