How Does Refraction Affect Image Location in a Bi-Radial Mirror?
  • Thread starter Jacob87411
  • Tags
    Mirror
In summary, the conversation discusses a piece of glass with an index of refraction of 1.5 and hemispherical ends with radii of 2 cm and 4 cm. The distance between the two ends is 8 cm. The conversation then mentions finding the location of an object's image due to refraction at the two spherical surfaces using the equation n2-n1/R = n1/d0 + n2/di. It is suggested to use the equation twice, once for each radius, and then average the results. The conversation also clarifies that the object is a lens and not a mirror, and suggests using the maker's equation (or its derivative) to find the focal length. The conversation concludes by stating the
Jacob87411
171
A piece of glas has an index of refraction of 1.5. The ends are hemispheres with radii 2 cm and 4 cm, and the distance that separates the centers of the hemispherical ends. A point object is located in air 1 cm from the left end of the glass. Find the location of the image of the object due to refraction at the two spherical surfaces.
So on the left end the mirror has a radius of 2 cm, and on the right it is of 4 cm and the two are separated by 8 cm.
Im thinking of using the equation: n2-n1/R = n1/d0 + n2/di. If so I will have to use it twice, one for each radius, which would give me two different di, then average them. Thats my thinking at least, not sure if its correct
Tis a lens, not a mirror...mirror's don't refract.
Find the focal length using the maker's equation (or its derivative).
The rest should be simple.
Ah..now i feel dumb
1/f = (n-1) (1/R1 - 1/R2)
n=1.5
R1=2
R2=4
Simple indeed, thanks
FAQ: How Does Refraction Affect Image Location in a Bi-Radial Mirror?
1. What is a mirror with 2 different radii?
A mirror with 2 different radii refers to a type of curved mirror that has two different curvatures, or radii, on its surface. This means that the mirror is not a perfect sphere or cylinder, but rather has a combination of both convex and concave surfaces.
2. How does a mirror with 2 different radii work?
A mirror with 2 different radii works by reflecting light rays that strike its surface. The curvature of the mirror determines how the light is reflected, with convex surfaces causing light to converge and concave surfaces causing light to diverge. This creates distorted or magnified images depending on the location of the object and the observer.
3. What are the applications of a mirror with 2 different radii?
Mirrors with 2 different radii are commonly used in optical instruments, such as telescopes and microscopes, to manipulate and magnify light. They are also used in automotive rearview mirrors to provide a wider field of view. In addition, these mirrors are used in makeup and dressing room mirrors to provide a more accurate reflection.
4. How are mirror with 2 different radii made?
Mirrors with 2 different radii are typically made by shaping glass or plastic materials through processes such as grinding, polishing, and coating with a reflective material, such as aluminum or silver. The curvature of the mirror can be controlled by the type and amount of pressure applied during the shaping process.
5. What are the advantages of using mirror with 2 different radii?
One advantage of using mirrors with 2 different radii is that they allow for a wider field of view and more accurate reflections compared to flat mirrors. They also have the ability to magnify or distort images for specific purposes, making them useful in various applications. Additionally, these mirrors can be made with different curvatures to suit specific needs and are relatively inexpensive to produce.
