How Do You Model Rainfall and Runoff on a Flat Surface?
analysis001
I would like to model rain hitting a surface and then running off of the surface. The surface would be a square, such as a slab of concrete, and the concrete would not be at any angle, so the rain would run off of all sides equally. This is a starting point for a small research project I am doing, and I'm not sure if my differential equations are right. Any help would be great.
Further information: The rain is falling at a constant rate. The ground surrounding the concrete has an unlimited capacity for rain. I am assuming that the concrete is initially fully saturated, so none of the rain will be absorbed into the concrete. I am also assuming that the rain is only falling on the concrete, not the surrounding ground.
\frac{dP}{dt}=c-g
\frac{dG}{dt}=p
\frac{dP}{dt} is the rate of change of water on the pavement.
\frac{dG}{dt} is the rate of change of water on the ground
c is the constant rate of rainfall.
g is the constant flow of water from the pavement onto the ground.
p is the rate at which water is flowing onto the ground.
Now that I think about it, g must equal p. So my new differential equations would be:
\frac{dP}{dt}=c-g
\frac{dG}{dt}=g
Does this look right? Thanks
Either you are using "P" and "p" and "G" and "g" interchangeably or you have not defined "P" and "G". Either is bad.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
