lxman
- 77
Hi all,
I am reading the moment library article, and in particular pertaining to this section
I am attempting to visualize what is explained.
I have created the following diagram (click for a larger image):
http://www.freeimagehosting.net/uploads/th.6994c04925.png
I believe that I have diagrammed correctly. The point where I get a bit confused is:
PR should be the vector extending from P to R2 along the Z axis (as I have drawn). Is this correct? Or would it be the vector from P to the existing point of application of F - R1?
Then the magnitude of the vector would be the cross product of vector PQ and the force vector? Or would it simply be the magnitude of PQ (a scalar) times the magnitude of the force vector (another scalar) to arrive at a scalar?
Thank you for your helping me clear this up.
Every force F has a moment about any point P.
To find the moment, draw R, the point of application of the force, and L, the line of the force, and draw the perpendicular line PQ from P to L (so both Q and R lie on L).
For the Moment of a velocity, R is the position of the centre of mass, and L is the line of the velocity.
Then the moment of F about P is the vector written "r x F" (pronounced "r cross F"), where r is the position vector PR. Its direction is perpendicular to both L and the line PR (and PQ). And its magnitude is PQ times F.
PQ is sometimes called the lever arm.
Note that if P is on the line L, then P = Q, so PQ = 0, so the moment of the force is 0.
