Understanding Moment of Inertia for a Beam Bending about the Y-Axis
The discussion focuses on calculating the moment of inertia for a beam bending about the y-axis. Participants clarify the formula for the moment of inertia, specifically addressing confusion around the term 80(16)(16^3) in the solution. They suggest alternative methods, including calculating the moment of inertia for a larger rectangle and subtracting the insets, which simplifies the process without needing the parallel axis theorem. The final calculations yield a consistent moment of inertia value of 720,896 mm^4 using both methods. Overall, the conversation emphasizes understanding the calculation methods and correcting initial mistakes.
wahaj
I'm supposed to solve for the maximum moment assuming the beam bends about the y-axis (not the z axis as shown in the image. Same image for different questions). I don't understand how to find the moment of inertia in this case. The solution gives the moment of inertia for the 80 x 16 mm part of the bar to be
I =\frac{1}{12}(80)(16^3) + 80(16)(16^3)
What I don't understand is where the 80(16)(163) comes from. Can some one explain?
I don't understand either. Sometimes, the authors of these solutions use obscure methods to find the answers. If in doubt about the I calculation, use a method which you understand better.
You could calculate I for an 80x48 rectangle and then subtract out the I for each of the 24x16 insets:
Iy = (1/12)*80*48^3 - 2*(1/12)*24*16^3 mm^4
This is a simple method because the parallel axis theorem is not required (everything has the same centroidal location w.r.t. the y-axis.
It's the stupid parallel axis theorem. I've only used that a few times before so I had completely forgotten about it. Your post reminded me of it. The second area moment of inertia using the parallel axis theorem is
I = I_x+Ar^2
here A is the area of the region. Anyways thanks for the help
I = I_x+Ar^2
The only problem is, it doesn't match the calculation in the OP.
If you wanted to split the Iy calculation into three segments, then you would have the following:
center segment: A = 16 * 32 mm^2 Iy = (1/12)*32*16^3 mm^4; no PAT required
upper, lower segments: A = 16*80 mm^2 Iy = (1/12)*80*16^3 mm^4
PAT = 16*80*24^2 mm^4,
So, the total Iy =
(1/12)*32*16^3 + 2*[(1/12)*80*16^3 + 16*80*16^2] = 720,896 mm^4
Alternately, by subtracting the two 16 x 24 mm cutouts from the 80 x 48 mm rectangle:
Iy = (1/12)*80*48^3 - 2*[(1/12)*24*16^3] = 720,896 mm^4
I realize I made a mistake in the OP. It's supposed to be 80(16)(16^2). However I like your second method better than the PAT.
