Moment of inertia of curved cuboid
The discussion focuses on calculating the moment of inertia for a curved cuboid, specifically one that is parabolically shaped around the y-axis. The user provides a mathematical equation for the curve and seeks assistance in determining the inertia components (Ixx, Iyy, Izz). A suggestion is made to treat the shape as a 2D extrusion, simplifying the problem to finding the inertia of a 2D slice. The conversation includes specific integrals for calculating Iyy and clarifies that Izz remains unchanged compared to a regular cuboid, while questions about Ixx and mass moment of inertia are raised. Overall, the thread emphasizes the need for clarity in applying the correct formulas and understanding the geometry involved.
kylem2122
Hi Physics Forums!
Moment of inertia question for you:
I have a cuboid, like the first one in this link
http://en.wikipedia.org/wiki/List_of_moments_of_inertia
only it is curved around the y (w in pic) axis such that the x (h in pic) axis touches the top and bottom ends of the cuboid and it is a parabolic curve that satisfies the following:
z=r*(1-(x^2)/((c/2)^2))
where r is the distance from the origin to the center of the cuboid and c is the chord length (in the x direction)
I need to find what the moment of inertia components would be, and I'm stumped. Any help would be greatly appreciated.
I can't picture what you're describing. If you can provide a sketch then I can probably figure it out.
If the shape is a 2D "extrusion" then it is sufficient to find the inertia of the 2D slice which should be a simple region in R2.
Thanks for the reply. I have made a simple 2D sketch for you. The y-axis is coming out of the page. Technically it is more like a flat plate than a cuboid but I would like to find the xx yy zz components of inertia if possible.
Ok this is simple. For Iyy do double integral of x^2 + z^2 dA on the region -c/2<x<c/2 and 0<z<z(x). This gives moment of inertia about the origin.
Okay, and I think the Izz will stay the same as a regular cuboid, right? What about Ixx? And for z(x) I use r*(1-(x^2)/((c/2)^2)) right? And should it be dm instead of dA for mass moment of inertia?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
