Momentof inertia and center of mass
The discussion centers on the concepts of moment of inertia and center of mass as presented in Serway's textbook. It highlights the confusion regarding the integration process used to derive these concepts, particularly questioning how the integration leads to seemingly trivial results. The moment of inertia for a rigid body is clarified as not being simply I = mR^2, as this only applies to point masses at a uniform distance from the axis. Additionally, the center of mass calculation is scrutinized for its treatment of mass distribution and the implications of variable distances in the integration process. Overall, the thread emphasizes the need for a deeper understanding of how integration applies to these physical concepts.
The Trice
momentof inertia and center of mass!
in book of serway : he says moment of inertia of a body is m(r^2).---->(1)
is mass of the body and r is the distance of the body.
but for a rigid body we will divide into particles of very small masses so i = E(Mi * (Ri)^2)
E() is submission function to number if i Th particles.
and he says if we decrease this mi or delta m i to very small amount
so I = lim(mi->0) mi*(ri)^2 which will equal integration( r^2 dm).
SO WHAT DID HE DO IF I SOLVE THE INTEGRATION IT WILL BE I=MR^2 the same as the first equation(1) !?
and also i have the same problem in center of mass
he says if we want to find x coordinate of center of mass so:
x=E(mi*xi)/M and again if we deal with a rigid body of infinite of particles it will be :
x=lim(mi->0) (mi*xi)/M = integration( x dm)/M
so what! if we solve this integration it will be xcm= (x* M)/M
so xcm=x (and u don't have x because x is xcm that u want to find so what did he do with this stupid integration !)
and also why did he make it integration( x dm)/M it seems tome as as mass in changing, but mass is constant for this particles!and even don't we get the constants out of integrtion soit would be xcm=x* integration(dm)/M so it would be 1=1!
and also in I=intefration(r^2 dm) why did he only change mi to dm and not also r^2 i mean he made the r is equal for all mass particles!
I = mr2 is true for a point mass, where r is the distance from the axis of rotation.
No. In general it's not true that I = mR2 for a rigid body. It would be true if all the mass is at the same distance from the axis.
Careful. Σ(xi*mi) ≠ Σ(xi)*Σ(mi), except in special cases.
so r is a function in terms of variable mass right!?
like when i say impulse is integration(f dt) so that means as time chnages the force changes ,soin inertia it means as mass changes!? the r changes!
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
