Momentum & Energy: 10kg Block Hit by 300m/s Bullet
2RIP
The non-moving 10-kg block is held frictionlessly inclined at 30 degrees by a stop at point A . A 0.010-kg bullet is moving at 300 m/s hits the block and embeds into it.
http://img386.imageshack.us/img386/9305/68906392wf8.jpg
I'm unsure which is the horizontal velocity.
m1v1=m2v2
Let m=0.01 kg, M=10 kg, v=300 m/s
mv=(m+M)v_{f}
v_{f}=(mv)/(M+m) = 0.3 m/s<br />
I thought the final velocity would be the initial horizontal velocity of the two combined masses, however, the solution says the horizontal velocity is vf*cos30=0.26 m/s and implies the velocity up the incline plane as v=0.3 m/s. Don't we need to be consistent with the direction of velocity in the momentum equation?
It kind of makes sense to me because if vx=0.3 m/s, then the inclined velocity would be greater than 0.3 m/s. But equation wise, I can't figure out how it happened.
Thanks
The horizontal velocity of the combined mass immediately before it interacts with the inclined plane is the final velocity you found by momentum conservation. But it's likely you must find the horizontal velocity due to the plane.
To do this you must decompose the final velocity into its components parallel and perpendicular to the inclined plane. If you think about where the perpendicular component is directed, you will see that you're just left with the parallel part. This is the initial velocity of the combined mass along the plane that you must decompose further into its horizontal, and vertical, component.
Having said all that though, my calculations disagree with the solution you have but I don't see what I'm doing wrongly.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
