Momentum:difference in final velocities
  • Thread starter Thread starter Sprinkle159
    Final
In a collision involving two equal-mass particles, the final velocities are constrained by the principles of conservation of momentum and energy. Given that one particle is initially at rest, the maximum and minimum final velocities depend on the type of collision. For a perfectly elastic collision, particle 1 can transfer its entire initial velocity to particle 2, while in a perfectly inelastic collision, both particles can move together at a reduced velocity. The final velocities cannot exceed certain limits, ensuring that energy conservation is maintained. Thus, the final velocities must fall within a specific range based on the initial conditions and collision type.
Sprinkle159
If the initial velocities of 2 particles are given, and the masses are equal, then is there some limit on what the final velocities can be?
m1v1i+m2v2i=m1v1F+m2v2F
(initial velocity of particle 2 is zero; v2i=0)
v1i=v1F+v2F
To clarify my question if particle 1 has an initial velocity of 50 m/s, then this equation says the final velocity of particle 1 could be -550 m/s, and then the final velocity of particle 2 would be 600 m/s, which are much larger then the initial velocity of particle 1. So is there some limit on what values the final velocities can have?
Yes. The collision would also need to satisfy conservation of energy.
... and that means that (in your example, where the masses are equal and particle 2 is initially at rest with the reference frame), there are two extreme possibilities [particle 1 stops and particle 2 takes particle's 1 initial velocity (perfectly elastic collision) and both particles stick to each other and move with velocity = 0.25 m/s (perfectly inelastic collision)] and a range between them but not beyond.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
