Momentum, force, energy and impact to break something.
The discussion revolves around the relationship between momentum, energy, and the force required to break or shatter glass when different weights are dropped or thrown at varying speeds. Participants explore how these factors interact in the context of impact mechanics, specifically comparing heavy objects dropped from a height to lighter objects thrown at high speeds.
  • One participant questions the difference in impact between a heavy object dropped at low speed and a lighter object thrown at high speed, noting that both scenarios involve different energy and momentum calculations.
  • Another participant introduces the concept of material response to impact, suggesting that faster impacts lead to higher forces and less time for the material to react, referencing the Charpy impact test.
  • A comparison is made between a 100 kg object moving at 1 m/s and a 1 kg object moving at 100 m/s, with claims about their respective forces upon impact with glass.
  • One participant challenges the calculated forces, expressing skepticism about the feasibility of a 100 kg object impacting with a force of 0.5 N.
  • Clarifications are made regarding the calculation of force and energy, with one participant asserting that energy is force applied over a distance, while another argues that the distance of strain on the glass varies with the speed of impact.
  • There is a suggestion that the distance over which force is applied is not the same in both scenarios, affecting the outcome of the impact.
Participants express differing views on the calculations of force and energy, with some agreeing on the need to consider material properties and impact dynamics, while others contest specific numerical claims and the assumptions behind them. The discussion remains unresolved with multiple competing perspectives on the mechanics involved.
Participants highlight the importance of strain and material response in impact scenarios, indicating that assumptions about uniformity in distance and material behavior may not hold true across different impact conditions.
Shadow_lawless
Ok I've been trying to figure out the difference between dropping something very heavy onto glass breaking the glass and throwing a penny at glass fast enough to cause it to shatter.
specifically what I am trying to figure out is how does energy, and change in momentum relate to force required to break or shatter glass.
for example 100kg weight moving at 1m/s would quite easly smash through glass.
momentum = 100kg -m/s
energy = .5x100x1 = 50j
it has not much change in momentum so what i don't understand is shouldn't that mean it has little force?
on the opposite side
say for example a weight 1kg is moving at 100m/s bounces of the glass but shatters it in the process ( i know must be really thick glass but stick with me)
momentum = 100kg-m/s
energy = .5x1x10000 = 5000j
it has a lot more energy and a massive change in momentum but doesn't manage to go through. why is this?
(both weights have the exact same size and shape)
Forgive me for if any of my calculations are wrong and I am completely missing something here, i haven't done physics since gcse level :/ was just pondering one day and it started bugging me that i didnt understand :*(
It is indeed an issue of energy, but the energy can be different for different speeds because of the way the material reacts to the impact (faster impact means higher force and less time for the material to react to the impact). Liik into the Charpy impact test and fracture energy/toughness.
http://en.m.wikipedia.org/wiki/Charpy_impact_test
Let's say we have a 100 kg bullet moving at 1 m/s and 1 kg bullet moving at 100 m/s shooting at thick glass with the same size and shape. Both have the same momentum (meaning force required to change the direction of the moving object is same). In this case, the force required to bounce back the heavier object is equal to the force required to bounce back the lighter one. F = ma.
So we can calculate that the 1 kg bullet hits with a force of 5000 N and the 100 kg bullet with a force of 0.5 N. Therefore, I think your numbers are fine, but the glass is not the same in both cases.
It's like saying 100 kg man at walking speed broke a glass, but a 1 kg ham moving at 360 kmph just bounced off.
You didn't say how you calculated that, but I don't believe the answers. One Newton is about equal to the weight of an apple. So you claim a "bullet" the weight of an adult human (100kg) will "hit" with a force of half a Newton? I don't think so...
My mistake, I meant 50 N.
Okay so Energy is force applied over a certain distance. Since the "certain distance" in this case is the same, we use the equation Work done = Force . Distance
Distance is not a factor in the case because we are simply comparing the two forces. Therefore, the proportion of the force of the two bullets is same as the proportion of the kinetic energies in this case.
The "certain distance" is not the same. When you apply the strain to the glass slower, it bends further before breaking.
In this case, the distance is close enough that the numbers he provided be proved inaccurate
  • · Replies 35 ·
