Calculating Momentum and Velocity in a Head-On Car Collision
In a head-on collision between two cars, the first car has a mass of 2.0 × 10³ kg and is moving at 9.0 m/s, while the second car has a mass of 1.5 × 10³ kg. The conservation of momentum principle is applied, stating that the initial momentum of the system equals the final momentum, which is zero after the cars come to rest. By calculating, the velocity of the second car before the collision is determined to be -12 m/s, indicating it was moving in the opposite direction. Consequently, the momentum of the second car before the collision is calculated to be 1.8 × 10^4 kg·m/s. Understanding momentum is crucial for solving such collision problems effectively.
Jimbo113453
When a car of mass 2.0 × 10³ kg moving at 9.0 m/s collides head on with a second car having a mass of 1.5 × 10³ kg, the cars lock and come to rest at the point of collision. (a) What was the momentum of the second car before the collision? (b) What was the velocity of the second car before collision?
I think this means that F of the first car equals F of the second car. So solve for F of the first car with F = ma. What's the acceleration though? :s Once I get that, equal it to (acceleration of second car)(1.5 × 10³). I can solve for the velocity of the second car somehow I think. Then I could get momentum with p = mv.
Excuse my ignorance. Physics is not my cup of tea. =(
u don't need to use F in this problem at all. its all about momentum.
yes u can solve for the velocity of the second car using conservation of momentum:
Pi = Pf
m1v1 + m2v2 = m1fv1f + m2fv2f
since they come to rest after collision the final momentum is 0.
so m1v1 = -m2v2
i think u can solve it from now.
m1v1 = m2v2
(2000 kg)(9.0 m/s) = -(1500 kg)(v2f)
v2 = -12 m/s
mv = p
(1500 kg)(12 m/s) = 1.8 × 10^4 kg×m/s
i won't check it with a calculator, but i see u got the point. :)
Thanks. =D
