Is Momentum the Same as Newton's Second Law?
  • Thread starter aloshi
In summary: F=\frac{dm}{dt}+\frac{dv}{dt}The difference between Newton's second law and change in momentum over time, more precisely the time derivative of momentum, is very subtle and negligible in most cases. In fact, Newton's second law is only generally correct. Force is always defined as a time derivative of momentum, and if the mass constant then we get Newton's second law.
aloshi
80
Hello!
if we write momentum of Ns, we drive 1kg * m / s and if we write Newton's second law of unity that is the same, (in N.s=Newton*seconds), So 1Kg*m/s^2 *s=1Kg*m/s which is the correct unit for momentum . It does not mean that momentum is the same as Newton's second law?
it's the same thing when you want to work, therefore, energy. it can express in different ways but ultimately it is the same;
[tex]mgh=energy\\ [/tex]
[tex]\frac{mv^2}{2}=energy\\ [/tex]
[tex]F\cdot \Delta s=energy(=work)[/tex]
so what is the difference between Newton's second law and the momentum?
[tex]F=\frac{dp}{dt}=m\frac{dv}{dt}=ma[/tex]
If mass isn't constant then we've got a product rule.
[tex]F=\frac{dm}{dt}+\frac{dv}{dt}[/tex]
but the mass at fault is always constant?
why the thing we write as a product, the mass will never be different
Sometimes the mass is different, some simple examples are of a rocket or a raindrop. From special relativity we also know that the mass isn't constant, but this factor is really negligible for real world applications. For most purposes, the mass is the same, and thus change in momentum over change in time is the same as force.
but I can not understand the difference between kinetic energy and momentum
Kinetic energy and momentum are very different. You could relate them by
[tex]KE=\frac{p^2}{2m}[/tex]
Maybe you could post a more specific question about what you do not understand between kinetic energy and momentum.
I can not understand the properties of momentum has. what is momentum? what distinguishes rörlsemängd from Newton's second law?
I guess there are a lot of answers to "what is momentum?" At the basic physics level, I think of momentum as a quantity that tells me how hard it will be to change the path of the object, such as how much an object with lots of momentum can alter another object. If a car is sliding quickly on ice, an object with lots of momentum, will I, an object with little momentum, be able to stop the car by walking into it? No.
Momentum is intuitive, just find your intuition for it.
Can you mention other things, then I will understand it better. thanks
Surely you mean
[tex]\mathbf{F}=\mathbf{v}\frac{dm}{dt}+m\frac{d\mathbf{v}}{dt}[/tex]
Momentum is exactly what its formula tells you: [itex]\mathbf{p}=m\mathbf{v}[/itex]. It is the mass times the velocity, thus it is a vector quantity that describes, as Isaac Newton put it, "the quantity of motion."
Now I do not understand. why should it be this:
[tex]F\cdot \Delta t=v\cdot dm+m\cdot dv[/tex]
How can we have in the:
constant v multiply variable with m + constant m multiply variable with v=[tex]F\cdot \Delta t[/tex]
Think of it as this (this is called the product rule, Leibniz's law, or derivation): By definition, the differential of two functions (we'll use mass and velocity here) is given by:
[tex]
d\left(m\cdot v\right)=(m+dm)\cdot(v+dv)-m\cdot v
[/tex]
so just expanding the product,
[tex]
d\left(m\cdot v\right)=m\cdot v+m\cdot dv+dm\cdot v+dm\cdot dv-m\cdot v
[/tex]
The first and last terms cancel. Now the argument is that since [itex]dm[/itex] and [itex]dv[/itex] are such infinitesimal amounts, then when we multiply them together, we get an even smaller amount and we can thus ignore it. So then
[tex]
d\left(m\cdot v\right)=m\cdot dv+dm\cdot v
[/tex]
Since the left hand side of the above equation is equal to the infinitesimal change in impulse ([itex]d(Ft)=F\,dt[/itex] for a constant Force) then it must be that
[tex]
F\,\Delta t=m\Delta v+v\Delta m[/tex]
jdwood983 said:
Surely you mean
Yes, of course. The troubles of doing math without actually writing it...:redface:
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
[tex]
in the end could be Please use this formula? one can say that this formula is useful when we watch photons hitting against a free agent?
Usually this formula would only be good for cases of http://www.relativitycalculator.com/mass_variable.shtml" to move forwards. The two links are pretty in-depth views (in English) of applications of the variable-mass impulse relation I derived above.In most cases of first year physics (and in some cases too, second year physics), mass is considered constant and the [itex]v\,\Delta m[/itex] term can be neglected because [itex]\Delta m=0[/itex]. In the cases where mass can change (low-speed, inelastic collisions), you would not use this equation but probably conservation of momentum:
[tex]
v_{1,initial}m_1+v_{2,initial}m_2=(m_1+m_2)v_{final}
[/tex]
Related to Is Momentum the Same as Newton's Second Law?
1. What is momentum?
Momentum is a measure of an object's motion, specifically the quantity of motion that an object has.
2. What does "Newton second" mean in relation to momentum?
"Newton second" is a unit of measurement for momentum, specifically the product of an object's mass in kilograms and its velocity in meters per second.
3. How is momentum calculated?
Momentum is calculated as the product of an object's mass and velocity, expressed in the formula p = m * v. In this formula, p represents momentum, m represents mass, and v represents velocity.
4. What is the relationship between momentum and force?
According to Newton's second law of motion, force is equal to the rate of change of an object's momentum. In other words, the more momentum an object has, the more force it will have.
5. Why is momentum an important concept in physics?
Momentum is an important concept in physics because it helps us understand the motion of objects and how they interact with each other. It is also a fundamental principle in the laws of conservation of momentum, which states that the total momentum of a closed system remains constant over time.
  • Mechanics
  • Science Fiction and Fantasy Media
