Momenum and differential of momentum
Momentum is defined as p=mv, and when differentiating momentum, the equation dp=dm*V+m*dV typically simplifies to dp=dm*V under certain conditions. The discussion highlights that this simplification assumes constant velocity with respect to the variable being differentiated, which is valid in one-dimensional cases. In scenarios involving special relativity or changing mass, such as in rockets, the second term m*dV cannot be ignored. The conversation emphasizes that the full formula for differential momentum is more complex and depends on the rigidity and rotational state of the body in question. Understanding these nuances is crucial for accurately applying momentum concepts in various physical contexts.
Cyrus
This was written on the board this last semester, and I can't seem to figure it out and its been bothering me to no end (mentally).
Momentum is defined as:
p=mv
therefore, if you want to find the differential momentum, it should be, mathematically speaking:
d(p)=d(mv)=dp=dm*V+m*dV
But differetial momentum is always written as:
dp=dm*V
I can't make sense out of what happened to the second term on the right side.
In fluid mechanics we have:
d(\rho VA)=\frac{d \rho}{\rho}+\frac{dV}{V} +\frac{DA}{A}
So d(p) for momentum should follow just the same using the product rule.
It makes sense conceptually, as each particle dm has a velocity V, and if you sum it over the body you get the total momentum, but it seems totally wrong mathematically.
classically, dm=0 in most cases. However, when special relativity is involved, mass does change. Another case where mass changes involves selfpropelled objects (rockets, airplanes) where fuel is burned off changing the mass.
Cyrus is asking what happened to the second term, m * dV. If the differential moment definition is correct as written above, then dp would always be zero according to you. Good question.
I suspect that the answer to your question only makes sense in a relativistic framework.
If our frame of reference is moving with the same acceleration as a given particle, then
m\cdot dV=0 since dV=0.
Then, in this setting,
dp=dm \cdot V+m \cdot dV=dm \cdot V.
However, in this framework, the only useful hint is that momentum affects mass.
Hmm.
Using the equation
dp = dm*V
must implicitly assume that V is constant wrt the variable by which you differentiate.
If that variable is length x, say, then m=m(x) and V=V(x). Then
\frac{dp}{dx} = V\frac{dm}{dx} + m\frac{dV}{dx}.
First, it's important to note immediately that this is only valid in one dimension.
The second term on the right is zero if dV/dx=0, which implies that V is a constant with respect to x. Note that V could actually be a function of some other variable (like time), but our consideration is only with respect to one variable, x. So it appears that dp=dm*V is only valid if you're talking about rigid, non-rotating? bodies in which velocity does not change with respect to the integration variable. The full formula would apply in more general cases.
I could be wrong, tell me what you think.
I think you might have misunderstood my question.
gabee said:
Hmm.
Using the equation
dp = dm*V
I think that you're mostly correct (there is one trivial case which is important to remember).
The body must be rigid (otherwise at some point along the body there might exist a place where dV \neq 0) and must be either non-rotating or rotational velocity is neglected. I suspect that for most cases that the body will be non-rotating.
Your formula is somewhat limiting because it doesn't generalize to higher dimensions, but I think that you have the right idea.
