Monstrous electromagnetism question.
  • Thread starter Thread starter Swatje
    Electromagnetism
The discussion revolves around a physics problem involving a cylinder with coils placed on a slope, requiring a minimum current to prevent it from rolling down. Key points include the understanding that the magnetic field does not perform work, meaning it cannot lift the cylinder uphill, regardless of the current. The forces acting on the cylinder, including gravitational and magnetic forces, are analyzed to determine the conditions under which the cylinder can oscillate without rolling uncontrollably. The conversation highlights the complexities of calculating the necessary current while considering energy conservation and the effects of induced electromotive force. Ultimately, the consensus is that it is impossible to prevent the cylinder from rolling downhill due to the nature of magnetic forces.
Swatje
[SOLVED] Monstrous electromagnetism question.
A slope variable: thèta
Amount of coils: 10.
Cilinder:
Diameter D
Length L
Massa M
Magnetic field B.
The cilinder has 10 coils wrapped around it, in rectangular form (over the top and bottom of the cilinder). It is placed on a slope with slope thèta, and the coils are horizontal at first. The current goes in a counter-clockwise motion when looked upon from above. There is a magnetic field with strength B, which is perpendicular and upwards. We release the cilinder to all forces. Give the formula for the minimal amound of amps going through the coils to make sure it doesn't keep rolling downwards.
F=BIL(sinalpha)
F=mg
rot E = - dB/dt
Many attempts, many failed. I just had this question on an exam, and man this was a brain teaser. The flux varies sinoïdal due to the rotation of the cilinder. Hence causing an electromotoric force. On the other side, we must find a minimal current to go through the coils, so that when the force pair of the lorentzforce on the coils is strong enough to fight the gravitational force of rolling downwards. This however, can't be at the first moment, because we place the coils horizontally, hence meaning that the force pair cancels each other out and has no tangential component. Once it begins rotating, it gathers momentum, so we must find a current, so that it cancels out the gravitational force, and it has enough time to reduce the angular speed to zero and reverse it. We also know that the law of faraday states that the amps are influence by the fluctuating magnetic flux through the coils. Hence creating a fluctuating voltage. This will however turn around in signum after rolling 90 degrees, hence it is (IM NOT SURE ABOUT THIS) that the reversal must happen in the first quadrant.
Any ideas on how to solve this monstrous question?
Actually, the magnetic field is said to be vertical, which is perpendicular to the horizontal coil. Since the cylinder is still, not rolling, the flux is not sinusoidal. It is constant.
Yep, that's what I meant. Once it starts rolling, it starts changing.
Lucky for you, it doesn't roll because we pump some number of amps through the coil to "make sure it doesn't [even start] rolling downwards."
See, it's really not a monster of a problem, just one force calculation: the force on a conducting coil in a magnetic field. You have the equations for that in Relevant equations, right?
Nono. It can start rolling, it just can't fall off.
So it can start rolling slightly, but then rollback, and maybe even oscillate as far as I know. The clue is to find the MINIMUM amount of amps so it doesn't go uncontrollably downwards.
It is even impossible not to roll, since the forces by the magnetic field are horizontal, in both directions. This means that it has no torque on the cilinder, and so it HAS to roll. But it just has to brake.
It's a ***** aint it? :D
Wow, I'm sorry for leading you in the wrong direction.
It does indeed seem like a [female dog] of a problem!
Hehe no problem. Anybody else got any ideas?
Ok, i had a small idea here, tell me if its mathematically correct:
If the cilinder starts rolling, let's say with at angle theta, let's let it roll over a certain height difference...
1/2*mv² + 1/2*I*omega = mgh
mv² + mr²omega² = 2mgh
v² + r²omega² = 2gh
2*r²omega² = 2gh
(Last step: omega = v / r)
Now let's look at the height difference h. We know that:
sin theta = h/s
Whereas s is the amount of distance covered on the slope.
omega = root(gh/r²)
omega = root([g*s*sin(theta)]/r²)
omega = root(s) * root ([g*sintheta]/r²)
Now "s" is equal to the amount of distance done on slope. So s=vt:
omega = root(vt) * root ([g*sintheta]/r²)
And v= omega-actual*r:
In which omega-actual is the actual speed in summation of all domega/dt.
omega = root(omega-actual) * root([g*sintheta]/r)
Now, I know the torque of the coils are:
tau = IL2rB*sin(omega-actual*t)
tau = m*r²*d(omega-coil)/dt
so:
d(omega-coil)/dt = (IL2B/rm)*sin(omega-actual*t)
Now i know (omega is the omega of gravity remember!):
d(omega)/dt = root([g*sintheta]/r) * (1/root(omega-actual) * d(omega-actual)/dt
Now i know, that the omega-actual is:
omega-actual = omega0 (=0) + t * d(omega)/dt + t * d(omega-coil)/dt
Now i know, that omega-actual must be nil at the period/4. (90 degrees) Otherwise we'll get in trouble and d(omega-coil)/dt will start reducing. So:
0 = P/4 * d(omega)/dt + P/4 * d(omega-coil)/dt
Now i can scrap the P/4 coefficients.
d(omega)/dt = - d(omega-coil)/dt
At t= P/4.
root([g*sintheta]/r) * (1/root(omega-actual) * d(omega-actual)/dt = - (IL2B/rm)*sin(omega-actual*t)
the sinus = 1.
But now I am just getting confused by the /0. I mustve made a mistake somewhere...
Hi Swatje,
I think they want you to use conservation of energy here. The amount of gravitational potential energy decrease is equal to the loop's magnetic potential energy increase. By considering the fact that the potential energy is increasing, you can find the proper orientation of the loop and the direction of the current at both the initial and final points (which are both places where the kinetic energy is zero).
So
Now the minimal amount of I, would be for omega*t to be as large as possible right? So let's say P = period/4, so after 90 degrees:
mgh = - M . B
mg*sin(theta)*s = - I * 2*r*L * B * cos (omega*t)
I = - (m*g*sin(theta)*s)/(2*r*L*B*cos(omega*t))
Now we want I as small as possible:
variables are s and omega*t. It also has to happen in first quadrant, and stopping anywhere before p/4, is just extra energy... So i assume:
s = pi*(1/2)*r
But then cosine won't work...
And if i let the cosine be as big as possible, i'll reach zero wt = zero, which is impossible too.
And does this account for faraday's law? If i run this minimal current through, it'll enlarge due to fluxvariations, and it'll top over the 90degree angle...
Is it even possible?
Look at the initial configuration: The cylinder is sitting on top of the plane. The net force due to the magnetic field is zero (it cancels along the sides - in fact by symmetry doesn't this always happen?). So at this point the only net force is gravity, so it rolls down the plane a little bit, converting potential energy into kinetic, and probably electromotive energy.
Now the things to note is that, in the problem:
There is no excess charge anywhere - all the charge is bounded together in the wire.
To lift the cylinder would require work to be done on the cylinder.
So, since the charge is all in the wire it can't be used to push the cylinder uphill. So we'd require the magnetic force to push it. But the magnetic force does no work!
Hence irrespective of the amount of current flowing through the wire, we couldn't stop it rolling downhill. (Though we would generate a nice EMF, as well as kinetic energy)
Summary: Since the magnetic field does no work it is impossible.
Swatje said:
So
mgh = - M . B
mg*sin(theta)*pi*r*(1/2) = - I * 2*r*L * B * cos (omega*t)
mg*sin(theta)*pi = - I*4*L*B*cos (omega*t)
I = - (m*g*sin(theta)*pi)/(4*L*B*cos(omega*t))
But does this account for faraday's law? If i run this minimal current through, it'll enlarge due to fluxvariations, and it'll top over the 90degree angle...
And won't the cosine be = 0? Hence making it
You'll need to have the energy equation modified a bit to take into account the intial and final magnetic potential energies of the loop:
<br /> (m g h_f - m g h_i) + (- u B \cos (\theta_f) - (- u B \cos(\theta_i) ) = 0<br />
\theta_f is 90 degrees, but \theta_i is not.
I think Faraday's law will predicts no induced current at the final point because the rotation of the cylinder is zero there (and so the field, loop area, and relative orientation are not changing).
Yes, at time = 0 the netforces cancel each other out, but when it starts rolling, the forces won't be strictly radial anymore and there will be a tangential component which exerts torque.
I understand that magnetic force does no work, but can't it oscillate slightly over an angle smaller than 90° degrees? Or will this oscillation start going out of control and eventually tip over the 90 degrees angle?
Hmm, i see what your getting at.
So:
mg (hi - hf) - I * L * 2r * B * (cosa theta f - cos theta i)
theta i = 0
So:
mg (hi - hf) - I * L * 2r * B * cos theta f = 0
Which is pretty much the same equation i had just before, where my h = hi - hf.
And faraday doesn't predict any current at final point indeed, does that also mean it doesn't influence the minimal initial current?
Hi fantispug,
A magnetic field does no work; but when a magnetic field affects a magnetic moment there is work being done. That's the point of having a magnetic potential energy. In this case I believe the battery which is driving the current is the source of the work.
So:
theta i = 0
Since theta_i=0, and theta_f=90, you get:
mg (hf - hi) - ( 0 - I L 2r B) =0
m g (delta h) + I L 2r B = 0
where (delta h) is negative.
Oh yes i see, small mistake ;).
so then:
I = - (m g delta h ) / (L * 2r * B)
and delta h, will approxiamtely be:
- sin theta * PI * r * 1/2
so
I = (m*g*pi) / ( 4 * L * B)
And you can discard any increase by faraday, because it will eventually have to stop rolling anyways, and then I = I original.
so then:
so
Minor point: I think you dropped the sin theta (that came from the change in height) from your final result.
Yep thx, and I also forget to add a 10 of the amount of coils.
alphysicist said:
Hi fantispug,
Ah, right, I was wondering about magnetic potential energy. The battery being a source of the work probably makes sense. I'm still having trouble visualising the situation though... if the current is reasonable I might try to construct it.
Im afraid your going to need a lot of tesla's to construct it. 1 maybe 1.5 tesla.
