More doubts in perturbation theory
This discussion centers on the complexities of perturbation theory in quantum mechanics, particularly in the context of degenerate states. It highlights the importance of selecting the correct linear combinations of unperturbed eigenstates, as incorrect choices can lead to meaningless results due to divergence in expressions involving energy differences. The necessity of diagonalizing the perturbation Hamiltonian within the set of degenerate zeroth-order states is emphasized, as outlined in standard quantum mechanics textbooks like Sakurai's "Modern Quantum Mechanics." The conversation also touches on practical examples, such as lifting degeneracy using sigma operators.
  • Understanding of quantum mechanics principles, particularly eigenstates and Hamiltonians.
  • Familiarity with perturbation theory, especially degenerate perturbation theory.
  • Knowledge of linear algebra concepts relevant to quantum state combinations.
  • Experience with quantum mechanics textbooks, such as "Modern Quantum Mechanics" by Sakurai.
  • Study the process of diagonalizing perturbation Hamiltonians in degenerate states.
  • Explore the implications of energy level degeneracy and its lifting using sigma operators.
  • Review examples of perturbation theory applications in quantum mechanics.
  • Read alternative quantum mechanics textbooks to compare different treatments of perturbation theory.
Students and professionals in physics, particularly those specializing in quantum mechanics, as well as educators seeking to clarify concepts related to perturbation theory and degeneracy in quantum systems.
Kashmir
Townsend, quantum mechanics
" In our earlier derivation we assumed that each unperturbed eigenstate ##\left|\varphi_{n}^{(0)}\right\rangle## turns smoothly into the exact eigenstate ##\left|\psi_{n}\right\rangle## as we turn on the perturbing Hamiltonian. However, if there are ##N## states
\left|\varphi_{n, i}^{(0)}\right\rangle \quad i=1,2, \ldots, N
## all with the same energy, it isn't clear which are the right linear combinations of the unperturbed states that become the exact eigenstates. For example, in the case of two-fold degeneracy, is it
\left|\varphi_{n, 1}^{(0)}\right\rangle \text { and }\left|\varphi_{n, 2}^{(0)}\right\rangle
or
\frac{1}{\sqrt{2}}\left(\left|\varphi_{n, 1}^{(0)}\right\rangle+\left|\varphi_{n, 2}^{(0)}\right\rangle\right) \quad \text { and } \frac{1}{\sqrt{2}}\left(\left|\varphi_{n, 1}^{(0)}\right\rangle-\left|\varphi_{n, 2}^{(0)}\right\rangle\right)
or some other of the infinite number of linear combinations that we can construct from these two states? If we choose the wrong linear combination of unperturbed states as a starting point, even the small change in the Hamiltonian generated by turning on the perturbation with an infinitesimal ##\lambda## must produce a large change in the state
1) We find the eigenstate of the total Hamiltonian using the below series ##\begin{aligned}\left|\psi_{n}\right\rangle &=\left|\varphi_{n}^{(0)}\right\rangle+\lambda\left|\varphi_{n}^{(1)}\right\rangle+\lambda^{2}\left|\varphi_{n}^{(2)}\right\rangle+\cdots \\ E_{n} &=E_{n}^{(0)}+\lambda E_{n}^{(1)}+\lambda^{2} E_{n}^{(2)}+\cdots \end{aligned}## What happens if I use the above series expansion for the wrong states? 2) Is it that the states which change abruptly aren't "the exact eigenstates" of the total perturbed Hamilton ?
1) You end up with meaningless expressions since the ##(E_1 - E_2)^{-1}## factors diverge.
2) No, the necessity to choose the "right" basis only arises in perturbation theory because we're looking for a power series in terms of ##\lambda## which cannot approximate jump-discontinuities.
So it is not possible to write the series expansion using"wrong" states ?
This case is known as "degenerate perturbation theory" and is discussed in any textbook. Specifically, you first have to diagonalize the perturbation V in the set of degenerate zeroth order states.
I'm having confusion reading my textbook 'McIntyre'
So try to find another book which fits your way of thinking better :-)
I like the treatment in Sakurai, Modern Quantum Mechanics.
Anyone??
Maybe you can think of it like this. This degeneracy can be lifted in several ways. For example, in a spin 1/2 problem, you can add either a sigma_z or a sigma_x term to lift the degeneracy. Assume you take the degenerate case as the limit of a small sigma_z potential tending to 0. Now if you add a sigma_x potential as a real perturbation, the convergence of the series will break down as soon as the term containing sigma_x becomes larger than the term containing sigma_z. In the limit of vanishing sigma_z, the perturbation series will not converge at all.
  • · Replies 21 ·
