Mossbauer data analysis - folding
The discussion focuses on the manual folding procedure for raw data from Mossbauer spectroscopy, specifically addressing issues with software not performing the task correctly. Participants suggest using free software alternatives for data folding and emphasize the importance of understanding the theory behind folding. A manual method is outlined, involving the selection of a central channel and calculating the square of the differences in counts symmetrically around this point to determine the correct folding point.
  • Understanding of Mossbauer spectroscopy data analysis
  • Proficiency in programming languages such as C or FORTRAN
  • Theory of data folding in spectroscopy
  • Familiarity with statistical methods for data comparison
  • Research free software options for Mossbauer data folding
  • Learn the theory of data folding in spectroscopy
  • Develop a custom program in C or FORTRAN for manual data folding
  • Explore statistical methods for determining optimal folding points
Researchers and analysts in the field of spectroscopy, particularly those working with Mossbauer data, as well as software developers interested in creating custom analysis tools.
NidhiA
Hi there, this looks like a great forum :-)
I would need help with the folding procedure for raw data from mossbauer spectroscopy. Our software doesn't, for some reason, fold the data correctly, so we want to attempt a manual procedure. But how do we determine the correct sense/direction of folding?
Thanks a lot for advice,
Nidhi
NidhiA said:
Hi there, this looks like a great forum :)
Nidhi
Hi,
There are lot of free software for folding (not convolution!) of the the raw data. What software do you use for analysis? But if you want to fold manually, then you should write your own C or FORTRAN program.. For this you should know the theory of folding.
Usually the folding point will be around the central channel.
After geting the raw spectrum choose the centre point and add then find the square of the difference of the counts before and after the centre channel count (symetrically around the selected folding point). Sum the differences and say it as 'x1'. Now take the next point of the central point and repeat the same procedure, and say it as 'x2'..Like wise find 3 point before and after the central point and repeat the procedure..Now see which 'x' is small, then that will be the correct folding point. After finding the folding point add the counts before and after the folding point to get the folded spectrum.
Hope it helps.
Rajini.
Thread 'Unexpected irregular reflection signal from a high-finesse cavity'
I am observing an irregular, aperiodic noise pattern in the reflection signal of a high-finesse optical cavity (finesse ≈ 20,000). The cavity is normally operated using a standard Pound–Drever–Hall (PDH) locking configuration, where an EOM provides phase modulation. The signals shown in the attached figures were recorded with the modulation turned off. Under these conditions, when scanning the laser frequency across a cavity resonance, I expected to observe a simple reflection dip. Instead...
  • · Replies 47 ·
  • · Replies 0 ·
