The discussion centers on controlling the rotation of a horizontal cylinder using an electric motor, with a focus on achieving precise positioning and programming multiple start/stop times. The context includes mechanical and electrical considerations, as well as potential sensor solutions for accurate control.
- Technical explanation
- Exploratory
- Debate/contested
- Mark seeks a method to control a cylinder's rotation with a 1hp motor, requiring it to return to the same position after each cycle.
- Some participants question the accuracy needed for stopping at 360 degrees, considering the motor's momentum and the gear reduction ratio.
- There is a suggestion to use an adjustable sensor that stops the motor slightly before reaching 360 degrees to account for momentum.
- Bob proposes using a retro-reflector and photo-detector or a micro-switch for stopping the rotation, noting that a DC motor could provide better accuracy than an induction motor.
- Mark expresses interest in the micro-switch idea due to its robustness in harsh conditions, asking for suppliers of necessary components.
- Bob mentions that while microswitches are available, they may require a relay or contactor to handle the motor's power needs.
Participants generally agree on the need for accurate positioning and the potential use of sensors, but there are differing opinions on the best approach and components to use. The discussion remains unresolved regarding the optimal solution for Mark's requirements.
There are limitations regarding the assumptions about the motor's performance, the effectiveness of different sensor types, and the specific requirements for the relay or contactor needed for the motor.
