Motion of 2 masses connected by a rod to a pendulum
The discussion revolves around a system involving two masses connected by a massless rod, which is suspended from a pendulum. Participants are exploring the conditions for equilibrium of forces acting on the system.
  • Participants are questioning which forces should be considered in the equilibrium analysis, particularly regarding the role of tension in the massless rod. There are discussions about the conditions under which the system can be in equilibrium, including considerations of dynamic versus static equilibrium. Some participants are also exploring the implications of the attachment point of the pendulum on the lower rod.
The discussion is active, with participants providing insights and questioning assumptions. Some have offered guidance on using symmetry and torque in the analysis, while others are exploring the effects of different configurations of the system. There is recognition of misunderstandings that have been clarified through edits to the original question.
Participants are considering the implications of the problem statement and whether a diagram was provided. There is an emphasis on the importance of the attachment point of the pendulum and the symmetry of the system in determining the behavior of the upper rod.
Jenny Physics
Find the equation of motion for the system of two masses connected by a massless rod hanging from a pendulum swinging from left to right and back. Use Newton's second law in terms of forces (not in terms of torques).
x and y forces
I am not sure which other forces I should consider besides those 3. I cannot consider tensions due to the massless rod on the masses since those will not add up to zero.
Jenny Physics said:
Homework Statement:: Find the equilibrium of forces condition for the system of two masses connected by a massless rod hanging from a pendulum.
Homework Equations:: x and y equilibrium of forces
Is the problem statement exactly as given to you?
Did the diagram come with it or is that your own interpretation?
It is hard to see how it could be in equilibrium unless the pendulum is vertical... unless it is a dynamic equilibrium, e.g. with the pendulum describing a cone about the vertical.
You are right, this was a misunderstanding. I edited the question.
I assume the upper rod joins the lower rod at its mid point.
In principle, you would use torque there to figure out the equations, but by symmetry you don't need to. Think whether the behaviour of the upper rod depends at all on the length of the lower rod. What difference would it make to that if it were shrunk to zero?
It doesn't depend on the length of the lower rod only because of the symmetry. But what if the pendulum were not attached right at the middle of the lower rod? How could I derive the equations without using torques?
It is provably impossible.
Consider the pendulum rod vertical and the other horizontal, all stationary. Forces alone say all is in balance, regardless where the joint is.
