Motion problem Final velocity of a dropped stone
A stone dropped from a height of 50 meters is analyzed for its final velocity using the equation v² = u² + 2a(x - x0), with gravitational acceleration set at -9.8 m/s². The calculation yields a final velocity of 31.30 m/s, which contradicts the book's answer of 9.9 m/s. The discussion highlights that the choice of direction for acceleration can affect the outcome, but the initial calculation appears to be correct. Additionally, it is noted that textbook problems should be posted in designated homework forums, even for self-study. The thread emphasizes the importance of proper categorization and descriptive titles for clarity.
debjit625
Hi everybody
I got this from a book
A stone is dropped from a height of 50 m and it falls freely. Calculate the velocity of the stone when it reaches the ground.
Assuming g = - 9.8 ms2 ,negative as its going downwards .
Using v2 = u2 + 2a(x - x0)
v2 = 02 + 2(-9.8)(-50-0)
I got v = 31.30 ms1
But the book have an answer of 9.9 ms1
so what's wrong with my process or the answer of the book is wrong ?
Thanks
debjit625 said:
Hi everybody
I got v = 31.30 ms1
Thanks
Careful picking your directions.
g = 9.8 m/s2 [Down] = -9.8 m/s2 [Up]
Your answer is correct though, maybe the book had a typo.
@Zondrina
I learned its a free choice i.e.. I can choose my positive and negative direction..
Yes it make sense that acceleration due to gravity is always downwards so that's its positive direction,but again mathematically I can choose it negative,if I see the motion in a Cartesian coordinate system.Am I wrong ?
Thanks
I found a notice,its not a homework so I didn't posted it in homework section.
debjit625 said:
@Zondrina
At the PF, all schoolwork-type questions need to go in the Homework Help (HH) forums. You should also use the HH Template when you post such questions (it is provided for you when you start a new HH thread) -- the Template helps to organize the way you present the question and your work on the solution.
Here is the text from your Notice:
Please post homework problems and textbook problems in the homework forums. Even if you're just self-studying and not taking a formal course, problems from textbooks always belong in the homework forums. I have moved it for you.
And here is a thread that should help you understand why the PF HH rules are the way they are:
https://www.physicsforums.com/showthread.php?t=373889
:smile:
Oh, and we ask that you please use very descriptive thread titles, to make it easier for other folks on the forum to decide if they are interested in clicking into your thread. I have added some more descriptive words to your thread title. Cheers! :smile:
