Motorcycle model and tire force
The discussion revolves around the application of tire forces in the derivation of a multi-body model of a motorcycle using Lagrangian mechanics. Participants explore the implications of force application points, particularly concerning the rear wheel, and the resulting effects on torque calculations and vehicle dynamics.
  • One participant describes issues with applying the longitudinal tire force, noting that the force appears to act at the wheel hub rather than the contact point, which affects torque calculations.
  • Another participant suggests that the direction of the represented force is incorrect, emphasizing the importance of the pavement-tire contact patch as a fulcrum in the model.
  • A question is raised about the meaning of the term "disappears" in relation to the force application, prompting clarification that the lack of generalized coordinates linking the wheel hub and tire contact point leads to a loss of torque contribution.
  • One participant proposes that including the rotational mass and angular velocity of the wheel might help address the issue, suggesting a relationship between wheel angular displacement and motorcycle displacement.
  • Another participant questions whether the model is intended to be extended to scenarios where the motorcycle is leaned over in a turn, indicating a potential complexity in the model.
Participants express differing views on the implications of force application points and the correctness of the equations used in the model. There is no consensus on the resolution of the issues raised, and multiple competing perspectives remain present.
Participants note limitations related to the generalized coordinates and their impact on torque contributions, as well as the potential need for additional factors such as wheel dynamics in the model.
LucaCaiaffa
I'm having issues in the application of tire forces while deriving a multi-body model of a motorcycle via Lagrange.
In particular, I considered several bodies that are: swingarm, main frame,
front upper fork, front lower fork and wheels.
I suppose the wheels to have zero slippage, then knowing the wheel rear torque
as ##T## and the rear radius as ##R_r## we have that ##F_x=T/R_r##
The kinematic model is correct and also forces from suspensions (the model
have been validated).The problem arises from the application point of ##F_x##.
While calculating the generalized force from ##F_x## the rear radius disappear,
meaning that the applied force acts like if it is applied in the center of the rear wheel instead of the contact point of the tire.
This results in same vehicle acceleration but different applied torques, but i don't know how to handle this issue.
I saw that many models found the same problem, but i don't get the point why this appears.
Thank you for your support
The represented force points in the wrong direction.
The pavement-tire contact patch is the fulcrum of a lever.
The chain applied force is at top of the rear sprocket, the reaction force is applied to the axis of the tire, which moves forward, pushing the chassis via swingarm.
What do you mean by "it disappears"?
No, it's not if it is the reaction force from the ground acting on the motorcycle.
I mean that there is no difference in applying the longitudinal tire force in the contact point or in the wheel hub.
This happens because no generalized coordinates relates the wheel hub and the tire contact point, and their jacobians for computing the generalized forces result the same.
For this reason I think I am "losing" a torque contribution in doing this.
Simplifying the problem, if i consider the motorcycle as a unique rigid body, I should have a torque contribution from the longitudinal force as ##T=F_xh## where ##h## is the height of the center of mass.
My model instead seems to lose the radius from the height of center of mass.
We will need to see your equation to help you further.
I don't have real experience with the Lagrange equation, but can't you include the rotational wheel mass and angular velocity? The wheel angular displacement ##\theta## does relate to the motorcycle displacement ##x## with ##x= \theta R_r##.
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 44 ·
9K
  • · Replies 18 ·
  • · Replies 49 ·
