Movable Wall in an Adiabatic System: Same Final Temperature?
The discussion revolves around a theoretical scenario involving an adiabatic container divided by a movable, heat-conducting wall, with one side containing a monatomic ideal gas and the other a diatomic ideal gas. Participants explore how the final position of the wall can be determined based on the thermodynamic properties of the gases, whether the final temperatures of the gases will be the same, and how real gases might behave differently compared to ideal gases.
  • Some participants question whether the wall will move at all, given that both gases start at the same temperature and pressure.
  • Others propose that the wall is forced to move slowly by an external rod, leading to a new thermodynamic equilibrium.
  • One participant suggests that if the final pressures and temperatures are known, it might be possible to determine how much the wall moved.
  • There is uncertainty about whether the final temperatures of the two gases will be the same, with some participants arguing that they should not be, while others express confusion about the initial conditions suggesting equilibrium.
  • Participants discuss how the behavior of real gases might deviate from the ideal gas predictions, though specifics are not fully explored.
Participants express differing views on whether the wall will move and whether the system is already in equilibrium. There is no consensus on the final temperatures of the gases or the implications of real versus ideal gas behavior.
Participants highlight the dependence on initial conditions and the role of external forces in moving the wall, which may complicate the analysis of the system's behavior.
Filipeml
TL;DR
A monatomic and a diatomic gas, initially at the same temperature and pressure, are separated by a movable, heat-conducting wall in an adiabatic container. How do they reach equilibrium?
Consider an adiabatic container divided into two chambers by a movable, heat-conducting wall. One side contains a monatomic ideal gas, while the other contains a diatomic ideal gas. Initially, both gases are at the same temperature and pressure. Over time, the wall moves until a new thermodynamic equilibrium is reached.
  • How can the final position of the wall be determined based on the thermodynamic properties of the gases?
  • Will the final temperatures of the two gases be the same? If not, what physical principle justifies this difference?
  • If the gases were real instead of ideal, how might the system’s behavior deviate from the predictions of the ideal gas model?
Science news on Phys.org
Are some initial p, V, N of the two gases given ?
Thanks. So I do not think the wall moves.
I'm assuming that the wall is forced to move slowly by a rod passing through the wall of the container.
Let n be the total number of moles of the gases in the two chambers and let V be the total volume of the chamber. Let ##\xi## characterize to the fractional volume of the gases in the two chambers (##-1<\xi<+1##), such that $$V_1=0.5(1+\xi)V$$and $$V_2=0.5(1-\xi)V$$so that, at all times, $$V_1+V_2=V$$Let ##\xi_0## be the fractional volumes at the initial state. For an ideal gas, show that, at all times, $$n_1=0.5(1+\xi_0)n$$and $$n_2=0.5(1-\xi_0)n$$
I am amazed that no one in PF has made an attempt to solve this very interesting problem.
Chestermiller said:
Estou assumindo que a parede é forçada a se mover lentamente por uma haste que passa pela parede do contêiner.
Seja n o número total de mols dos gases nas duas câmaras e seja V o volume total da câmara. Seja ##\xi## caracterizado pelo volume fracionário dos gases nas duas câmaras (##-1<\xi<+1##), tal que $$V_1=0,5(1+\xi)V$$e $$V_2=0,5(1-\xi)V$$de modo que, em todos os momentos, $$V_1+V_2=V$$Sejam ##\xi_0## os volumes fracionários no estado inicial. Para um gás ideal, mostre que, em todos os momentos, $$n_1=0,5(1+\xi_0)n$$e $$n_2=0,5(1-\xi_0)n$$
Obrigado por sua resposta!
Filipeml said:
TL;DR Summary: A monatomic and a diatomic gas, initially at the same temperature and pressure, are separated by a movable, heat-conducting wall in an adiabatic container. How do they reach equilibrium?
I'm also confused. Why are they not already in equilibrium?
Both gases have the same temperature so there should be no heat transfer through the wall.
Both gases have the same pressure so the wall shouldn't move.
What am I missing?
What am I missing?
As Chestermiller said,
So Question #1 from the op becomes,
Q #1: if you can't see the moving rod, and someone told you the final pressures and temperatures, then could you figure out how much the rod moved?
Q #2 : Would you expect them to report the same temperature for both sides of the container?
Q #3: What if they were real gases? How would things change?
Q #2 : Would you expect them to report the same temperature?
The problem statement confused me.
The wall doesn't move by itself "until they reach equilibrium".
The system is already in equilibrium and the wall is moved by an external force, so work is done on the system and it moves to a new equilibrium.
  • · Replies 135 ·
9K
  • · Replies 35 ·
  • · Replies 60 ·
10K
  • · Replies 22 ·
