Movement of Water - Increasing day length
The discussion revolves around calculating the change in Earth's day length due to the movement of water from the equator to mid-latitude reservoirs, focusing on the conservation of angular momentum. The user seeks clarification on the concept of radius of gyration and its relevance to the problem, particularly in relation to a rotating spherical mass. They aim to equate the initial angular momentum of the Earth with its final angular momentum after the water's relocation. The user expresses uncertainty about formulating the angular momentum of the water in its new position. Overall, the thread highlights the complexities of applying angular momentum principles to this specific scenario.
Sekonda
Hey,
I have a problem which I'm having trouble solving, it concerns the conservation of angular momentum.
I am given a volume of water that is held behind dams in the mid-latitudes on the Earth and am asked to determine the change in length of the day due to the movement of the water into these reservoirs. The water is moving from the equator, I believe, into these mid latitude based reservoirs. I am given the radius of gyration, radius and density of the Earth, I am still unsure what exactly the radius of gyration is! I am also told the density of water.
Now the problem is solved by using conservation of angular momentum; now what I think I have to do is find the angular momentum about a diameter axis of the Earth initially with its initial angular velocity and then to equate this to the sum of the angular momentum of the Earth about the same axis with its final angular velocity, and the angular momentum of the water in its new location.
I'm not sure if this is correct, and I'm a bit confused of how to formulate the last term - the angular momentum of the water in its new location.
Thanks for any help guys!
S
I'll try and simplify my questions!
What exactly is the radius of gyration and how is it applicable to a rotating (around a diameter fixed axis) solid spherical mass in which a small amount of mass, equally distributed around the equator, is moved to the mid-latitudes, I'm guessing 45 degrees.
I think this is at the heart of my issue with this particular problem, thanks guys!
i'd give it a go for a random guess at about 0.2ms
hope this helps alot:)
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
