Moving Electrons in a Uniform Magnetic Field
The discussion focuses on calculating the acceleration, horizontal distance, and final velocity of an electron moving in a uniform magnetic field. The acceleration is determined to be 7.03 x 10^13 m/s², leading to a calculated horizontal distance of 0.096 m. The vertical component of the velocity upon striking the plate is found to be 1.6775 x 10^6 m/s, but there is confusion regarding the inclusion of a horizontal velocity component. Participants emphasize the importance of considering both vertical and horizontal components in the final velocity calculation. The thread concludes with acknowledgment of a common oversight in physics problems related to vector components.
Jkalirai
An electron is fired at 4.0 × 10^6 m/s horizontally between the parallel plates, as shown, starting at the negative plate. The electron deflects downwards and strikes the bottom plate. The magnitude of the electric field between the plates is 4.0 × 10^2 N/C. The separation of the plates is 2.0 cm.
a) Find the acceleration of the electron between the plates.
b) Find the horizontal distance traveled by the electron when it hits the plate.
c) Find the velocity of the electron as it strikes the plate.
1) m * a = ε * q
2) ∆d = v * ∆t + ½ * a * ∆t^2
3) v[SUB]2[/SUB][SUP]2[/SUP] = v[SUB]1[/SUB][SUP]2[/SUP] + 2 * a * ∆d
245982
a) We can solve for acceleration by looking at FNETy
FNETy = FE (G is negligible)
FNETy = m * a
The mass (m) of an electron is 9.1093836 x 10-31 kg.
The elementary charge (q) of an electron is -1.60217662 x 10-19 C
a = ε * q / m
a = (4.0 x 102 N/C * 1.6022 x 10-19 C) / 9.1094 x 10-31 kg
a = 7.0353 x 1013 m/s2
Our electron is fired south and hits the positive plate.
Therefore, the acceleration of our electron is 7.03 x 1013 m/s2.
b) To find the horizontal distance, we first solve for ∆t
∆dy = v2 * ∆t + ½ * a * ∆t2
We know that our initial vertical velocity is 0 m/s.
(0.02 m) = ½ * 7.0353 x 1013 m/s * ∆t2
∆t2 = 0.02 * 2 / 7.0353 x 1013
∆t = √ 5.6856 x 10-16
∆t = 2.3845 x 10-8 s
Now we solve for ∆dx
Our horizontal acceleration is equal to 0 therefore,
∆dx = v1x * ∆t
∆dx = (4.0 x 106 m/s * 2.3845 x 10-8 s)
∆dx = 0.09538 m
Therefore, our horizontal distance is equal to 0.096 m [E].
c) To find v2 we use the corresponding equation,
v2y2 = v1y2 + 2 * a * ∆dy (v1y = 0 m/s)
v2y2 = 2 * (7.0353 x 1013 m/s2) * (0.02)
v2y = √ (2.81412 x 1012)
v2y = 1.6775 x 106 m/s
Therefore, the velocity that the electron strikes the plate at is 1.6775 x 106 m/s.
I am not sure if my answer for part c) is correct or not. I've seen other people with older threads get answers close to 4.3 x 106 but it didn't make sense to me because they used the initial velocity of x in place of the initial velocity of y, whereas I stated that my initial velocity of y is equal to 0.
Any advice is appreciated.
Likes Merlin3189
Your work looks very good (but I did not get out my calculator to check the arithmetic).
However, part (C) asks you to find the velocity of the electron as it strikes the positive plate. You found the vertical component of the velocity. Is there also a horizontal component?
Likes Jkalirai
Hello Jkalirai, ##\qquad## :welcome: ##\qquad##!
A few house rules to begin with:
Don't write " 4.0 × 106 m/s ". Please use the button superscript ( under
245979
) or use ##\LaTeX## : ##4.0 \times 10^6 ## m/s .(I notice you did use the subscript button for " 3) v2^2 = v1^2 + 2 * a * ∆d "but they don't get rendered !? Strange ... Then: have pity on helpers "as shown " suggests there exists a sketch or a drawing -- post it. And "35. Let south and east be positive. " doesn't help if south and east don't occur anywhere (*) . (Even though I do know what you mean - telepathy ?)
(*) well, 'is fired south' does occur - but I think you mean east...And finally, but most importantly:
1) check your math for your third relevant equation
v2y = √ (2.81412 x 10^12) so ##v_{2,y}>10^6## m/s where you write
v2y = 3.14389 x 10^5 m/s
2) as Tsny helped you with that already, I don't have to ask what you do with the original 4e6 m/s :wink:
Likes TSny
Huh, you know... I actually sat down for like 20-30 minutes and really wondered why I didn't even consider a horizontal portion. I worked through the problem again, I knew that horizontal acceleration was 0, meaning that the initial velocity is the same as the final velocity. After that, it's just a matter of putting the pieces together where v2 = √ (vx2 + vy2). Well anyways... after working through it I got a similar answer to what every other thread seems to be saying. Seems like a silly mistake to make but thanks for the heads up.
Don't write " 4.0 × 106 m/s ". Please use the button superscript ( under View attachment 245979 ) or use ##\LaTeX## : ##4.0 \times 10^6 ## m/s .(I notice you did use the subscript button for " 3) v2^2 = v1^2 + 2 * a * ∆d "but they don't get rendered !? Strange ...Then: have pity on helpers "as shown " suggests there exists a sketch or a drawing -- post it. And "35. Let south and east be positive. " doesn't help if south and east don't occur anywhere (*) . (Even though I do know what you mean - telepathy ?)
Thanks for the tips, though I can't quite fix the subscripts and superscripts in the "Relevant Questions" tab. Not sure what's going on there.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
