Convert MPH to lb-force - Easy Guide
  • Thread starter Thread starter elmarsur
Converting miles per hour (mph) to pound-force (lb-force) is not directly possible, as they measure different physical quantities: speed and force, respectively. To calculate force from a deceleration scenario, one can use the formula F = MA, where F is force, M is mass in pounds, and A is acceleration. The discussion highlights confusion about the conversion process, emphasizing the need for context when discussing units of measurement. Ultimately, speed cannot be converted into force without additional information regarding mass and acceleration. Understanding the distinction between these units is crucial for accurate calculations.
elmarsur
How would I convert mph into lb-force?
Thank you.
If it's decelerating from the given mph to zero, multiply by the mass in pounds: F = MA
hmm … i don't understand either the question or the answer :confused:
what is the context? why exactly are you trying to convert a speed into a force?
You don't convert between these two. These are units of completely different quantities. It's like asking how to convert between feet and hours. You can't.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
