Mr.Stewart is confusing me. Estimating sums
  • Thread starter Thread starter flyingpig
    Confusing Sums
flyingpig
[PLAIN]http://img842.imageshack.us/img842/1404/unledro.png Now what I don't understand is this part
[PLAIN]http://img821.imageshack.us/img821/7479/unledoq.png
Is he trying to say that \frac{1}{2n^3} = R_n? Is that how he deduced that \frac{1}{2n^3} < 0.0005?
No, it's saying that Rn <= 1/(2n2), and if he can find an n for which 1/(2n2) < 0.0005, then Rn will be < 0.0005.
Given the sum \sum a_nwith a_n &lt;b&gt;decreasing&lt;/b&gt; (and, in order that the sum be convergent, they must be decreasing to 0), mark those points (n, a_n) on a graph, draw vertical lines from each such point, and a horizontal line from each to the left so that you get a sequence of rectangles, each having width 1, height a_n and so area a_n. The total area in all those is the sum \sum a_n. &lt;br /&gt; &lt;br /&gt; Now, draw a curve through the upper &lt;b&gt;left&lt;/b&gt; corner of each rectangle. Call that function f(x). Then f(n)= a_n for each positive integer n. Also, notice that the curve passes &lt;b&gt;beneath&lt;/b&gt; the horizontal line on each rectangle. That is, the area beneath the curve, in each rectangle, is &lt;b&gt;less&lt;/b&gt; than the area in that rectangle and the total area under the curve, from x= 1, is &lt;b&gt;less&lt;/b&gt; than the total area of the rectangles.&lt;br /&gt; &lt;br /&gt; That is, &lt;br /&gt; \int_1^\infty f(x)dx&amp;amp;lt; \sum_{n=1}^\infty a_n&lt;br /&gt; &lt;br /&gt; Taking f(x)= 1/x^3 when f_n= 1/n^3 does exactly that.
So then R_n\leq \frac{1}{2n^3}, but he also says R_n\leq 0.0005, so how could he turned it into
\frac{1}{2n^3}&lt;0.0005
If he chooses n so that \frac{1}{2n^3}&lt;0.0005\,, then R_n\leq \frac{1}{2n^3}&lt;0.0005\quad\to\quad R_n&lt;0.0005
I'm looking at what you posted, and it says
R_n\leq \frac{1}{2n^2}
Note the exponent of 2, not 3.
Stewart doesn't say that 1/(2n2) < 0.0005. He says he wants to find n so that this is true.
If he can find such a number n, then he will have Rn < 0.0005.
Thanks for catching that Mark44 lol, I didn't realize I had a 3 instead of a 2. I don't know why I keep thinking it is a 3.
I just want to ask, when he solved it, you should get n&gt;\sqrt{1000}
\sqrt{1000}\approx 31.6 and you round up to 32 because there is no such thing as "half a term", but what if n \sqrt{1000}\approx 31.2 (31.2 I made up randomlly), would we still choose n to be 32 or 31? At first I thought it would be 32, but my book chooses 31.
It was an another example in my book.
For 1/(2n2) < .0005, you need n > sqrt(1000) ~ 31.6, but you also want n to be an integer, so you take n = 32. If you chose n = 31, then 1/(2n2) ~ .00052, which is larger than .0005.
If you needed to find n > sqrt(973) ~31.2, I would take n = 32. If your book chooses a different number, I would need to see more information about this other problem.
[PLAIN]http://img35.imageshack.us/img35/1369/unledlh.png
For part c), they did this
\frac{1}{3n^3}&lt;\frac{1}{10^5}
\frac{1}{n^3}&lt;\frac{3}{10^5}
Now here is where it gets confusing, I did some algebra and I found you eventually have to flip over the inequality sign, but if I were to just invert both sides, does that mean I also have to change inequality? Anyways
[PLAIN]http://img64.imageshack.us/img64/9656/unledif.png
Yes. Assuming that a and b are both positive, a < b ==> 1/a > 1/b.
A geometric explanation is that if b is to the right of a, then 1/b will be a smaller number than 1/a.
flyingpig said:
Anyways
[PLAIN]http://img64.imageshack.us/img64/9656/unledif.png[/QUOTE]
They found n \approx 32.2, so they're taking n > 32. Since n is an integer, this means that n >= 33.
But why n > 32? The approxixmate is 32.2, which means that it should be n > 32.2
Why choosen n > 32? If it was 32.1, wouldn't the error be no longer within 10^-5?
Keep in mind that n is an index, so it's an integer[/color] value. The inequalities n > 32, n > 32.2, n > 32.1 are all equivalent to n >= 33, for n an integer.
