Multiply and Divide Rational Expressions
When dividing rational expressions, the second expression should be flipped and multiplied with the first. The process involves multiplying the numerators and denominators, factoring completely, and canceling common factors. In the provided example, the cancellation leads to a final answer of 5a(a - 1) or 15a^2 - 15a, both of which are correct. The confusion arose from the interpretation of how to handle the separate fraction during cancellation. The final answer confirms the correct understanding of the multiplication and cancellation process.
AngelShare
I thought I knew what I was doing (because I've done this before) but I can't see what's happening in this one example...I understood what was going on right up until the last step.
If you are dividing two rational expressions, flip the second expression and multiply the two rational expressions together.
Multiply the numerators and the denominators. Because you want to cancel out the common factors, it is best not to actually multiply the numbers but instead to just write them together.
Factor the numerator and denominator completely.
Cancel the common factors.
The final answer consists of the remaining factors.
Q. 18a^2 (a-1)/5 * 25/6a
A. 5a(a - 1)
I either made a mistake understanding the problem, or one of the (Q or A) has to be wrong.
\frac{{18a^2 \left( {a - 1} \right)}}<br /> {5} \cdot \frac{{25}}<br /> {{6a}} = \frac{{3a \cdot 6a \cdot \left( {a - 1} \right) \cdot 5 \cdot 5}}<br /> {{5 \cdot 6a}}
Now, what would cancelling out common factors give?
Aha! I thought so because that makes no sense. I'll post where I think it went wrong to see if I'm right. ^_^
Lesson work:
Step 2- Cancel the common factors
2*3*3*a*a*(a - 1)/5 * 5*5/2*3*a (What's bolded is what is left behind after cancellation.)
Step 3- Write the final answer
5a(a - 1)
My work:
3a(a - 1) * 5
3a^2 - 3a * 5
15a^2 - 15a
Being that the 5 was a separate fraction before cancellation, I thought I had to distribute it instead of just multiply it by one so...^_^
Could someone please tell me if my answer is correct before I move on? ^_^
Yes, your answer is correct. It can be written either 15a2- 15a or 15a(a-1).
