Multiplying Fractions: Simplifying with GCF
  • Thread starter Thread starter science_rules
    Fraction
26 replies · 4K views
science_rules
I would just like to know if I got this right. ((x2 + 2x + 1)/(18cw3) times ((12c3w)/(x2 - 1)) = (12c3wx2 + 2x12c3w + 12c3w)/(18cw3)(x2 - 18cw3
((x2 + 2x + 1)/(18cw3) times ((12c3w)(x2 - 1))
(12c3wx2 + 2x12c3w + 12c3w)/((18cw3)(x2 - 1)) = (12c3wx2 + 2x12c3w + 12c3w)/(18cw3x2 - 18cw3
I accidentally used a subscript all the way through instead of a power, argh!
science_rules said:
##(12c_3wx_2 + 2x12c_3w + 12c_3w)/(18cw_3x_2 - 18cw_3##
On the right side one of the terms is ##2x12c_3w##. Should that have been ##2x^{12}c^3##? Also, you're missing a right parenthesis.
It should have been as haruspex said: (x2 + 2x + 1)/(18cw3) times (12c3w)/(x2-1)
haruspex said:
Do you mean ##\frac{x^2+2x+1}{18cw^3}\frac{12c^3w}{x^2-1}##?
If so, there is a lot of cancellation available. Factorise the two expressions involving x.
Yes, that is what I meant.
(x+1)(x+1)/(18cw3) times (12c3w)/(x-1)(x+1)
The x+1 cancels, leaving: (x+1)/(18cw3) times (12c3w)/(x-1)
haruspex said:
More cancellation to go. Look at the constants, look at the powers of c and w.
(x+1)/((3w)(6cw2)) times ((3w)(4c3))/(x-1) = (x+1)/(6cw2) times (4c3)/(x-1)
The 3w is canceled
science_rules said:
The 3w is canceled
I meant that 3wc is canceled, leaving: (x+1)/(w2) times (4c2)/(x-1)
haruspex said:
You made a mistake with the constants.
Should it be: 3cw(w2) and 3cw(4c2)??
Oops I meant: 3cw(6w2) and 3cw(4c2)
haruspex said:
Yes.
Thank you for your help
haruspex said:
Yes.
So the answer is: (x+1)/(6w2) times (4c2)/(x-1)
science_rules said:
The 3w is canceled
Instead of adding new posts each time you discover something you should have said, you can edit the post you want to change.
The constants can be further simplified, and then you should bring it together so you have one fraction.
Like this?: (x+1)/(6w2) times (4c2)/(x-1) = 4c2x + 4c2/6w2x-6w2 = 2c(2cx+2c)/2w(3wx-3w)<------(Answer)?
1)
2) I think you can leave the nominator as ##2c²(x+1)##, and similarly for the denominator. Certainly would give a better readable result.
Samy_A said:
1)
How did you get 2c2(x+1) when it was 4c2/(x+1)?? Isn't the numerator supposed to be 2c2(2x+2)??
And the denominator is supposed to be: 2w2(3x-3)??
science_rules said:
How did you get 2c2(x+1) when it was 4c2/(x-1)?? Isn't the numerator supposed to be 2c2(2x+2)??
You are still not doing all the simplification you could. In what you posted above, each parenthetic term has a factor that can be taken outside. Having done that, one of the primes occurs above and below the line.
Okay, I think I have it now: (x2 + 2x + 1)/(18cw3) times (12c3w)/(x2-1) = (x+1)2(12c3w)/(18cw2)(x+1)(x-1) Cancel the (x+1) = (12c3w)(x+1)/(18cw2)(x-1) Cancel the c and w = (12c2)(x+1)/(18w)(x-1) divided by 3 (numerator and denominator) = (4c2)(x+1)/(6w)(x-1) divided by 2 (numerator and denominator) = (2c2)(x+1)/(3w)(x-1) Answer
Enclose the entire denominator in parentheses.
(2c2)(x+1)/((3w)(x-1)) .
You could've reached the last step by recognizing that 6 is the GCF for the numerator and denominator.
