ahmadkza86
- 1
Can someone help me to design the multirange ohm meter using permenant magnetic moving coil movement...
The discussion focuses on designing a multirange ohm meter utilizing a D'Arsonval movement, which is a type of permanent magnetic moving coil movement. Key components include a series resistor for voltage measurement (multiplier resistor) and a parallel resistor for current measurement (shunt resistor). The design requires a DC power supply in series with the meter movement and the resistance to be measured, with adjustments made to the power supply voltage and series resistor to achieve the desired measurement range. Digital ohmeters employ a current source connected to the probes, measuring voltage across the probes to determine resistance values.
PREREQUISITESElectronics enthusiasts, electrical engineering students, and professionals designing measurement instruments will benefit from this discussion.
ahmadkza86 said:Can someone help me to design the multirange ohm meter using permenant magnetic moving coil movement...
Integral said:One version is called a D'Arsonval movement.
The resistor in series (current mode) or parallel (voltage) determines the range. Figure the value of resistor to give you a range, then a switch to change ranges. Pretty basic stuff.
