Naked singularities, and Hawking
JustinLevy
I've read that Hawking believes the Universe somehow prevents naked singularities, and made a bet about it with Kip Thorne.
But it seems to me that if you take a static black hole and continually inject material into it with high angular momentum, eventually you would have a naked singularity (since you'd eventually get an extremal black hole). This seems very general to me. Actually, since the momentum of a particle is unbounded, technically you should be able to do this with just a single particle, correct?
Clearly the answer can't be that simple.
What am I missing?
No. Hawking's bet with Thorne (and John Preskill) was concerned with the idea of information loss in black holes.
The idea that the universe prevents the formation of naked singularities refers to any of the various forms of the cosmic censorship conjecture, possibly the single most important unproven conjecture in mathematical relativity.
I think there are some general arguments that you can spin a black hole up to a = M in principle, but not beyond. As matter is injected into the black hole to increase a, M also increases, and the maximum value for a/M is 1. Thorne showed that, in practice, a black hole can be spun up to only a = 0.998M.
Hawking also bet Preskill about the existence of naked singularities; see
http://www.theory.caltech.edu/~preskill/bets.html.
In THE ELEGANT UNIVERSE (1999) Brian Greene in chapter 13, Black Holes: A string/M theory Perspective, has a great discussion on naked/hidden singularities and how Calabi Yau shapes, perhaps the fundamental description of additional dimensions in our universe, can shield us from them. It turns out there are many ways space tearing transitions can occur, many ways Calabi Yau shapes can continuously transform, and how certain physical configurations appear as either black holes or elementary particles...yes, it appears a massive black hole can transition to a massles particle following a three dimensional sphere collapse to a pinched point...corresponding to a black hole!
Wikipedia at http://en.wikipedia.org/wiki/Conifold_transition has a brief mathematical discussion. In the discussion here, "smooth transitions" I believe means "continuous" shielding/hiding underlying singularities. As usual while Wikipedia may be technically correct, it's descriptions are all too often rather opaque without other sources.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
