Other Narrowness of field of research?
  • Thread starter Thread starter pierce15
    Field Research
In the discussion, the focus is on the challenge of selecting a specific field of physics for research, particularly for undergraduate students. It emphasizes that while interdisciplinary work is possible, most research requires a deep investment in a narrow area to contribute effectively. As students progress, they must develop a strong understanding of their chosen problem, including existing work and methodologies, which demands significant time and effort. The conversation highlights the importance of exploring various fields through reading, attending talks, and engaging with faculty and peers to identify interests and strengths. By the fourth year, students typically have a clearer direction, often narrowing down options rather than trying to cover too many areas. It’s acknowledged that not all students will find their ideal field on the first attempt, and there are opportunities to shift focus if needed.
pierce15
Hello,
I'm still a freshman undergraduate, so it's very early to decide what field of physics I will spend most of my time working in. However, I'm wondering how narrow one's research has to be -- for example, is it feasible to do work in both atomic physics and nuclear physics? How about throwing condensed matter into that mix? Does that answer depends on the nature of the research, i.e. theoretical vs. experimental?
Just realized this probably should have been in career guidance, sorry about that.
Whatever you do will be narrow. It might straddle some traditional boundary and be called "interdisciplinary" but it's going to be narrow.
By the time you get to a PhD and beyond, what you'll discover is that in order to contribute valuable research you need a considerable degree of investment in a particular problem. You need to know the basic physics behind it. You need to know what work other people have done on the problem, and what work people are currently doing. You have to understand enough about the problem to be able to convince other people that your approach to it is going to yield a result that is worthwhile. You have to design a scientific approach to the problem, work through it, and revise it (often many times). You have to write up your results and present them.
All of this, as you might imagine, takes a considerable investment of time and effort. So the more you diversify your efforts, the less progress you'll make on anyone problem.
What tends to happen when people start to do work in multiple areas is that they have gotten very good at a small number of solution types that can be applied to multiple problems in multiple areas. They also collaborate well - contributing a narrow piece of expertise to a problem that requires multiple experts.
Well, that's a bummer. How does one usually go about picking a field, then, given that one will not be able to try out the vast majority of fields before choosing?
It's not a trivial thing. I think a lot of people struggle with trying to optimize this kind of problem while being constrained to sample only a few points.
It helps to read a lot, attend departmental talks, and to talk informally with your professors and graduate students about the projects they are working on. You can also explore through undergraduate research opportunities and senior thesis projects. Usually by about fourth year most students will have an idea of what general direction they want to go in. Sometimes all they've done is eliminate some possibilities and that's okay. I think often as you move through undergrad, you tend to discover certain strengths - some people really enjoy coding, others like hand's on work, etc. Looking for a project that plays to your strengths and what you enjoy tends to be a good strategy.
And not everyone gets it right the first try. Some people can start working on a PhD project and realize they have no passion for the field they're in. In that case they can usually change projects, if something else is available.
TL;DR Summary: I want to do a PhD in applied math but I hate group theory, is this a big problem? Hello, I am a second-year math and physics double major with a minor in data science. I just finished group theory (today actually), and it was my least favorite class in all of university so far. It doesn't interest me, and I am also very bad at it compared to other math courses I have done. The other courses I have done are calculus I-III, ODEs, Linear Algebra, and Prob/Stats. Is it a...
Yesterday, 9/5/2025, when I was surfing, I found an article The Schwarzschild solution contains three problems, which can be easily solved - Journal of King Saud University - Science ABUNDANCE ESTIMATION IN AN ARID ENVIRONMENT https://jksus.org/the-schwarzschild-solution-contains-three-problems-which-can-be-easily-solved/ that has the derivation of a line element as a corrected version of the Schwarzschild solution to Einstein’s field equation. This article's date received is 2022-11-15...
