Nasty Integral - Help with Trig Substitution
mrworf
[itex] \int_{-p}^{p} \frac{2p}{(1+v^2)\sqrt{p^2 + v^2 +1 }} dv[/itex]
[itex]1 + \tan{\theta}^2 = \sec{\theta}^2[/itex]
I thought the best way to go about this was to rename some constants.
Let [itex]\alpha^2 = 1 + p^2[/itex] so that we are left with:
[itex] \int_{-p}^{p} \frac{2p}{(1+v^2)\sqrt{\alpha^2+ v^2 }} dv[/itex]
i then make the variable substitution:
[itex]v = \alpha \tan{\theta}[/itex]
[itex]dv = \alpha \sec{\theta}^2 d\theta[/itex]
we now have:
[itex] 2p \int_{-p}^{p} \frac{1}{(1+\alpha^2 \tan^2{\theta})\sqrt{\alpha^2(1+\tan^2{\theta} )}} \alpha \sec{\theta}^2 d\theta[/itex]
[itex] 2p \int_{-p}^{p} \frac{1}{(1+\alpha^2 \tan^2{\theta})\alpha \sec{\theta}} \alpha \sec{\theta}^2 d\theta[/itex]
[itex] 2p \int_{-p}^{p} \frac{ \sec{\theta}}{(1+\alpha^2 \tan^2{\theta})} d\theta[/itex]
at this point i hit a roadblock - the (1 - \alpha \tan{\theta} ) term seems to be an inextricable pain . other substitutions leave me with a similar problem.
If anyone can point me in the direction of a better trig substitution, or perhaps an identity then your help would be greatly appreciated.
thanks for reading
-mrworf
on Phys.org
mrworf said:
[itex]\int_{-p}^{p} \frac{2p}{(1+v^2)\sqrt{p^2 + v^2 +1 }} dv[/itex]
Let [itex]\alpha^2 = 1 + p^2[/itex] so that we are left with:[itex] \int_{-p}^{p} \frac{2p}{(1+v^2)\sqrt{\alpha^2+ v^2 }} dv[/itex]
we now have:
[itex]2p \int_{-p}^{p} \frac{1}{(1+\alpha^2 \tan^2{\theta})\sqrt{\alpha^2(1+\tan^2{\theta} )}} \alpha \sec{\theta}^2 d\theta[/itex]
[itex]2p \int_{-p}^{p} \frac{1}{(1+\alpha^2 \tan^2{\theta})\alpha \sec{\theta}} \alpha \sec{\theta}^2 d\theta[/itex]
[itex]2p \int_{-p}^{p} \frac{ \sec{\theta}}{(1+\alpha^2 \tan^2{\theta})} d\theta[/itex]
thanks for reading
-mrworf
Hello mrworf. Welcome to PF !
First of all, [itex]\ \sec\theta^2\[/itex] means [itex]\ \sec(\theta^2)\,\[/itex] whereas [itex]\ \sec^2\theta\[/itex] means [itex]\ (\sec\theta)^2\ .\[/itex] I'm sure you want the latter for this problem.
Also, you need to change the limits of integration to reflect the substitution you did.
right on, with sammyS' suggestion, my equation becomes:
[itex]2 p \int_{\tan^{-1}{\frac{p}{\alpha}}}^{\tan^{-1}{\frac{-p}{\alpha}}} \bigg[ \frac{\sec{\theta}}{(1+\alpha^2 \tan^2{\theta})} \bigg] d\theta[/itex]
[itex]\displaystyle 2 p \int_{\tan^{-1}{\frac{p}{\alpha}}}^{\tan^{-1}{\frac{-p}{\alpha}}} \bigg[ \frac{\sec{\theta}}{(1+\alpha^2 \tan^2{\theta})} \bigg] d\theta[/itex]
I admit, it's still quite nasty !
  • · Replies 19 ·
  • · Replies 34 ·
