How Is the Natural Linewidth of a Laser Determined?
In summary, the natural line width of a laser is the finite range of wavelengths or energies of the photons it emits. This can cause issues when using nonlinear materials, such as crystals, that may not react properly to photons with the wrong wavelength. The line width can vary depending on the material used, such as in the case of semiconductor lasers, but it is difficult to calculate accurately."
komalpahwa65
What is natural line width of laser? how one can determine it e.g. for semiconductor lasers?
A laser works by exciting electrons in a very specific manner such that when the electron falls back into its ground state, it will send out a photon with a specified wavelength. But as one can show (done in http://www.uio.no/studier/emner/matnat/fys/FYS4110/h10/undervisningsmateriale/LectureNotes2010.pdf p 118, also see p 120) the photons that are sent out doesn't have the exact wavelength, but rather a finite width of wavelengths (or energies). So if you have a laser (say a Helium-Neon with wavelength 632.8 nm), you will get some photons with wavelength 632.5 nm etc. This could for example be a problem if you have a nonlinear material such as a crystal that you want to send your laser beam through, and the crystal behaves incorrectly to the photons with wrong wavelength.
I have only been doing calculations on a so-called three-level laser, which is extremely simplified, but in this case our assumptions were simply made, hoping that they are experimentally valid. In the real case, the line width is probably dependent of what material you use (such as some semiconductor), but I would guess this is hard to calculate.
What is the natural linewidth of a laser?
The natural linewidth of a laser refers to the range of frequencies that make up the emission spectrum of the laser. It is determined by the lifetime of the excited state of the laser's atoms or molecules.
How does the natural linewidth of a laser affect its performance?
The natural linewidth of a laser can affect its performance by limiting the precision and stability of the laser's output frequency. A narrow linewidth is desirable for applications that require high precision, such as spectroscopy or telecommunications.
What factors determine the natural linewidth of a laser?
The natural linewidth of a laser is primarily determined by the properties of the laser's gain medium, such as the excited state lifetime and the type of transition that produces the laser emission. Other factors that can influence the linewidth include the laser's operating temperature and external factors such as vibration or mechanical stress.
Can the natural linewidth of a laser be controlled?
Yes, the natural linewidth of a laser can be controlled through various techniques such as using a cavity to enhance the coherence of the emitted light, or using external feedback to stabilize the laser's output frequency. Additionally, some types of lasers, such as distributed feedback lasers, are designed to have a narrow linewidth inherently.
How does the natural linewidth of a laser differ from its linewidth in operation?
The natural linewidth of a laser refers to the intrinsic linewidth of the laser's emission without any external influences. In operation, the laser's linewidth can be broadened due to various factors such as temperature fluctuations, external feedback, or nonlinear effects. The difference between the natural linewidth and the linewidth in operation is known as the "linewidth enhancement factor."
  • Quantum Physics
  • Atomic and Condensed Matter
  • Quantum Physics
  • Quantum Physics
