Natural logarithm equation
In summary, to solve the equation 16-12ln(7x)=47 for x, you need to reverse the steps that have been done to x. This includes dividing by -12, taking the exponential, dividing by 7, and subtracting 16. The final answer for x is e^-61/9/4. However, a calculator is needed to fully evaluate this.
buzzingbee
Solve the following equation for x
16-12ln(7x)=47
I know I need to isolate x . however I am unsure how to get ln(7x) separated.
what i have so far
ln(7x)=-31/12
e^(ln(y)) = y
e = 2.71828...
You always solve an equation for a variable such as x by doing the reverse of what has been done to it (to both sides, of course).
If you were asked to evaluate 23- 9ln(4x) (I am using different numbers so you can apply the same idea to your problem) for a given value of x, you would:
1) multiply by 4: 4x.
2) take the natural logarithn: ln(4x)
3) multiply by -9: -9 ln(7x)
4) add 23: 23- 12 ln(7x)
To solve for x, do the opposite: do the opposite of each step, in the opposite order. The opposite of "add 23" is "subtract 23", the opposite of "multiply by -9" is "divide by -9", the opposite of "multiply by 4" is "divide by 4", and the opposite of "take the natural logarithm" is "take the exponential".
Starting from 23- 9 ln(4x)= 85:
1) subtract 23: 23- 9ln(4x)- 23= 84- 23, -9ln(4x)= 61
2) divide by -9: -9ln(4x)/(-9)= 61/(-9), ln(4x)= -61/9
3) take the exponential: eln(4x)= e-61/9: 4x= e- 61/9[/tex]
4) divide by 4: 4x/4= e-61/9/4, x= e-61/9/4.
You will need to use a calculator to actually evaluate e-61/9.
1. What is a natural logarithm equation?
A natural logarithm equation is a mathematical equation that uses the natural logarithm function, denoted as ln, to solve for an unknown variable. The natural logarithm function is the inverse of the exponential function and is commonly used in many fields of science and mathematics.
2. How do you solve a natural logarithm equation?
To solve a natural logarithm equation, you can use the properties of logarithms, such as the product, quotient, and power rules, to simplify the equation. Then, you can use algebraic methods to isolate the variable and solve for its value. It is important to check your solution to ensure it is valid for the given equation.
3. What is the difference between a natural logarithm and a common logarithm?
A natural logarithm uses the base e, which is approximately equal to 2.718, while a common logarithm uses the base 10. This means that a natural logarithm equation will have an ln function, while a common logarithm equation will have a log function. Additionally, natural logarithms are commonly used in exponential growth and decay problems, while common logarithms are used in problems involving pH levels and earthquake magnitudes.
4. Can you use a calculator to solve a natural logarithm equation?
Yes, most scientific calculators have a function for natural logarithms. You can use the "ln" button to input the logarithm function, followed by the number or expression inside the parentheses. Make sure to use parentheses around any expressions to ensure correct calculation. However, it is important to understand the steps and methods to solve a natural logarithm equation by hand before relying on a calculator.
5. What are some real-world applications of natural logarithm equations?
Natural logarithm equations are commonly used in fields such as economics, physics, and biology. They can be used to model exponential growth and decay, such as population growth or radioactive decay. They are also used in finance to calculate compound interest and in physics to model the rate of change in a system. In biology, natural logarithm equations are used to model growth and decay of bacteria and other organisms.
  • Differential Equations
