Nature of the roots of the equations
  • Thread starter Thread starter shivam01anand
    Nature Roots
The discussion revolves around determining the nature of the roots for the equations x^4 - 4x + 1 = 0 and x^4 - 4x - 1 = 0. Participants debate the effectiveness of Descartes' Rule of Signs, with some expressing skepticism about its practical utility, while others argue it can be beneficial when combined with derivative analysis. The conversation highlights the importance of understanding the maximum possible roots and the characteristics of polynomial equations. Clarification is sought on whether the equations are identical, as this affects the analysis. Ultimately, the consensus suggests that Descartes' Rule, alongside knowledge of polynomial zeros, can yield insights into the roots of these equations.
shivam01anand
The given equations are;
Q.1) Find the no of + roots of the equation x^4 -4x+1=0
Q.2) Find the no. of negative roots of the eqn x^4-4x-1=0
Q.3) Find the no of complex roots of the eqn x^4-4x-1=0
yes indeed but according to our maths teacher it's pretty rubbish in practical use because it just gives the MAXIMUM possible with any equation no matter the respective conditions..
no help i guess from that :(
Have you learned about derivatives yet? This problem seems really well suited for a first and second derivative test and after a little argument you can answer the question.
I'm not sure if this is how your teacher wants it completed, I forget if derivatives are covered in pre-calculus, it's been awhile since I looked at a book.
The Rule of Signs is but one tool in your previously empty toolbag.
You should know how many roots these equations will have. By careful use of this fact and the Rule of Signs, it may help you to narrow the numbers of each type of root.
I think you'll find it has some value here. (And please clarify whether the three equations are supposed to be the same. As posted, they're not.)
Assuming that all three questions are regarding the same equation, then you are being asked about the zeros of one of the two following polynomials.
##\displaystyle P(x)= x^4 -4x+1 ##
OR
##\displaystyle Q(x)=x^4 -4x-1 ##
For either case, Descartes' Rule of Signs turns out to be very useful when combined with some other observations.
Maybe it's not rubbish for these polynomials.
Yes i know a good deal on how to do the derivatives now after a year.
but these three separate questions were part of a question bank on the chapter QUADRATIC EQUATIONS.
So i guess calculus goes out of the window for now.
The only way to solve this is by discarte? and ofc derivative
Well, you haven't resolved the question regarding which function (or equation) is being asked about.
If you're being asked about the roots of x4-4x-1 = 0 , then Descartes along with a nominal amount of knowledge about the zeros of polynomials, will give all the answers. While Descartes' Rule gives the maximum number of positive roots or maximum number of negative roots, if the number is fewer than either maximum, if the number of either is less than the maximum, then the amount that it is less is an even number. So for this equation there is one positive root and one negative root. How many roots does a degree 4 polynomial equation have?
Please check your PMs. It is against the rules of these forums to post a schoolwork question without showing any effort toward the solution. It is also against the PF rules for other posters to offer help when you show zero effort in your first post in a thread.
